Shortening code help.
by theonlyski on Fri Nov 30, 2012 5:29 pm
Hey guys, looking for a more efficient way to do this.
void SerialOut(){
  Serial.print("PSI: ");
  Serial.print(PSI);
  Serial.print("    ");
  Serial.print("PumpTemp ");
  Serial.print(PumpTemp);
  Serial.print("    ");
  Serial.print("PumpMode: ");
  Serial.print(PumpMode);
  Serial.print("    ");
  Serial.print("RadarMode: ");
  Serial.print(RadarMode);
  Serial.print("    ");
  Serial.print("HornMode: ");
  Serial.println(HornMode);
I tried:
SerialOut(){
  String space = "    ";
  String output = "";
  output = output + "PSI: " + PSI + space + "PumpTemp: " + PumpTemp + space + "PumpMode: " + PumpMode + space + "RadarMode: " + RadarMode + space + "HornMode: " + HornMode;
  Serial.println(output);
Which works, 32 times... then the board locks up and has to be reset.
I know there is a random issue with the values not being defined first, but it's weird that it worked 32 times exactly then dies.
Here I was troubleshooting the new sensor when I hadn't thought about all the code that I had changed! :oops:
Also, if anyone needs an easy to use PSI sensor, I just picked one up off ebay for $30 that works like a champ. Linear output and all! :D
theonlyski
Re: Shortening code help.
by adafruit_support_mike on Sun Dec 02, 2012 1:20 am
I had to spend five minutes looking at that to understand how it would work at all.. ;-)
In C, strings are arrays of characters, so 'adding' strings with the '+' operator would actually add the pointer values for each string. It's possible to use that constructively, but not like this.
A little digging reminded me that the Arduino environment also defines String objects, which can be concatenated with '+'. At a guess, your code is allocating new String objects every time you call the function, and by the 32nd time you get a memory overflow.
What you want is the 'printf' function described on this page: http://arduino.cc/playground/Main/Printf
With that, your code would look like so:
printf(
    "PSI: %d  PumpTemp: %d  PumpMode: %d ...\n",
    PSI, PumpTemp, PumpMode, ...
