Arduinos sending data between each other
by drummerboyx on Fri Dec 07, 2012 7:58 am
Hey!
So I have two Arduinos. One is a Duemilanove and one is a Nano. The Duemilanove receives DMX data, and I want to send 5 channels of the data to the Nano to send over the serial port to my computer. I can't use the Duemilanove to do that, because it's communicating with the timer chip (for DMX receive). I don't think I can use digital read/write and connect 5 wires to the digital outs of one to the digital ins on the other right? Because digitalRead/Write can only produce HIGH and LOW.
Any ideas on how to do this?
drummerboyx
Re: Arduinos sending data between each other
by adafruit_support_bill on Fri Dec 07, 2012 8:19 am
You should be able to use SoftwareSerial on the Duemilanove to send it back to the computer. Unless I am missing something, having a Nano as a middle-man doesn't offer much value.
by drummerboyx on Fri Dec 07, 2012 8:58 am
Well it's communicating with the timer chip at 25,000 baud through the serial port - so it's in use. I need another Arduino to send the incoming DMX data to my computer using serial.
drummerboyx
by drummerboyx on Fri Dec 07, 2012 8:59 am
OH! SoftwareSerial!!! BRILLIANT :) I'll definitely try that out asap. Thanks, a lot!
drummerboyx
