The big offender is the function I wrote that does the Mars time conversions. My code compiles to 29,872 bytes. Commenting out the function reduces it to 16,020 bytes. So this one function is taking up more than 13k! Here's the code:
uint8_t MinTens = 0;
uint8_t MinOnes = 0;
uint8_t SecTens = 0;
uint8_t SecOnes = 0;
uint8_t UTCHourTens = 1;
uint8_t UTCHourOnes = 2;
uint8_t UTCDateOnes = 1;
uint8_t UTCDateTens = 0;
uint8_t UTCMonthCode = 1;
uint8_t UTCYearsOnes = 2;
uint8_t UTCYearsTens = 1;
uint32_t MarsSol;
uint8_t MarsHourTens;
uint8_t MarsHourOnes;
uint8_t MarsMinTens;
uint8_t MarsMinOnes;
void ComputeMarsTime(uint64_t Epoch)
uint32_t UnixTime = 946684800L; // Jan 1, 2000 epoch
uint8_t temp;
temp = UTCYearsTens * 10 + UTCYearsOnes;
UnixTime += (uint64_t) temp * 31536000L;
// Now correct for leap years. Note that 2000 is NOT a leap year. We are also subtracting 1 because the current
// year is dealt with later.
if ( temp )
temp--;
temp -= temp % 4;
temp /= 4;
UnixTime += (uint64_t) temp * 86400L;
if ( UTCMonthCode >= 2 )
UnixTime += 2678400L;
if ( UTCMonthCode >= 3 ) {
UnixTime += 2419200L;
// Correct for current year leap year. Note that 2000 is NOT a leap year.
if ( UTCYearsTens != 0 || UTCYearsOnes != 0 ) {
if ( ( UTCYearsTens * 10 + UTCYearsOnes ) % 4 == 0 )
UnixTime += 86400L;
if ( UTCMonthCode >= 4 )
if ( UTCMonthCode >= 5 )
UnixTime += 2592000L;
if ( UTCMonthCode >= 6 )
if ( UTCMonthCode >= 7 )
if ( UTCMonthCode >= 8 )
if ( UTCMonthCode >= 9 )
if ( UTCMonthCode >= 10 )
if ( UTCMonthCode >= 11 )
if ( UTCMonthCode >= 12 )
temp = UTCDateTens * 10 + UTCDateOnes;
UnixTime += (uint32_t) temp * 86400L;
temp = UTCHourTens * 10 + UTCHourOnes;
UnixTime += (uint32_t) temp * 3600L;
temp = MinTens * 10 + MinOnes;
UnixTime += (uint32_t) temp * 60L;
temp = SecTens * 10 + SecOnes;
UnixTime += (uint32_t) temp;
uint64_t JD_UTC = (UnixTime * 1000000LL) / 86400LL + 2440587500000LL;
uint64_t JD_TT = JD_UTC;
JD_TT += (35LL*1000000LL + 32184000LL) / 86400LL; // Note: TODO MAKE LEAP SECOND CONFIGURABLE
uint64_t J2000 = JD_TT - 2451545000000LL;
uint64_t MSD = J2000 - 4500000LL;
MSD *= 1000000000LL;
MSD /= 1027491252LL;
MSD += 44796000000LL - 960LL;
MSD -= Epoch; // Epoch of mission time. Set to 0 for MTC.
MarsSol = MSD / 1000000LL;
uint32_t MTC = (MSD % 1000000L) * 24L;
byte MTCHour = MTC / 1000000L;
MarsHourOnes = MTCHour % 10;
MarsHourTens = ( MTCHour - MarsHourOnes ) / 10;
MTC = (MTC % 1000000L)*60L;
byte MTCMin = (MTC - MTC % 1000000L)/1000000L;
MarsMinOnes = MTCMin % 10;
MarsMinTens = ( MTCMin - MarsMinOnes ) / 10;
Any advice would be appreciated. Thanks!
