Today I was trying to code an intervalometer. Since I like to code all from the start I used the raw data and coded everything. It did not work and I figured out that I used a 62ms seconds delay instead I needed a 65ms seconds delay.
My question is the following if I ever decode an IR emitter how can I figure out that I need to use a 65ms delay instead of whatever number I get from my decoder?
Thanks a lot
M.
IR Tutorial question
Re: IR Tutorial question
Ah! That is the joy of reverse engineering. Without (accurate) documentation, you just have to experiment a bit to find what works.
