I am playing with the blink sketch, and have three LEDs blinking on different pins. What is odd, is that pin 13 produces a bright LED, while the other pins are much dimmer. I am using a 330 ohm resistor on each negative leg.
I am using pens 13, 12,& 8. I have also tried using my mac book pro usb and a 9V battery for power supplies.
Any idea as to what is going on here?
Thank you,
OSS
Something Odd on the UNO
- westfw
Re: Something Odd on the UNO
Did you remember: pinMode(12, OUTPUT) in your setup() function ? Without that, the digitalWrite() will switch the "pullup" on and off, but not provide full "drive" on the pin. This can cause dim flashing of LEDs.
Ahhh,
Thank you westfw, I missed that in the initial Blink program; should have printed it out.
You solved my concern.
Thank you,
OSS
Thank you,
OSS
