Battery pack not working
by Marcele64 on Tue Jan 01, 2013 5:02 pm
Hi-
The LED's light up fine when my Flora is connected to the computer. However, they do not turn on when I connect the battery pack to the flora and turn the switch to ON. I have triple checked that the batteries are installed correctly and have even changed the batteries. Still, it does not work.
Do I have a defective battery pack?
Marcele
Marcele64
Re: Battery pack not working
by adafruit_support_mike on Tue Jan 01, 2013 5:39 pm
The easiest way to check is to test the pack's output wires (or the points where power comes into your Flora) with a voltmeter.
by Marcele64 on Sat Jan 05, 2013 7:11 pm
When I put the positive lead on the Vbatt and the negative lead to ground on my flora board, my multimeter measures 10.5mv.
Am I doing this right?
Marcele64
by adafruit_support_bill on Sat Jan 05, 2013 8:54 pm
Can you post a photo of how you have everything connected?
by Marcele64 on Sun Jan 06, 2013 2:48 pm
The battery pack is connected to Flora. I've got the positive lead touching the VBatt pin and the negative lead touching ground.
Marcele
Marcele64
by Marcele64 on Sun Jan 06, 2013 2:51 pm
I tried to upload the photos, but they didn't appear. Hold on. They're too big.
Marcele64
by adafruit_support_bill on Sun Jan 06, 2013 2:52 pm
You should be able to re-size them to about 800x600
by Marcele64 on Sun Jan 06, 2013 2:55 pm
Ok, here they are.
Marcele64
by adafruit_support_bill on Sun Jan 06, 2013 3:06 pm
Contact support@adafruit.com with a link to this thread. They will arrange a replacement for you.
by Marcele64 on Sat Jan 12, 2013 12:23 pm
Hi-
I received the replacement battery pack in the mail several days ago. Thanks - the delivery was so fast. I didn't get a chance to use it until today. I installed the batteries, plugged the new one into my Flora and still, the led's on the board do not light up. My multimeter reads 5.1 mv. I highly doubt that two battery packs in a row could be defective. I'm assuming there's a bad connection on the Flora board. The USB connection works fine.
What do you think?
Marcele
Marcele64
by adafruit_support_bill on Sat Jan 12, 2013 12:33 pm
I agree. Two defective battery packs is unlikely. I suspect there is bad connection from the battery connector on the Flora. Contact support@adafruit.com once more with a link to this thread and ask for a replacement Flora.
