Inaccurate result when combining LM35 + XBee
by cutie_lovely_92 on Fri Jan 04, 2013 4:21 am
I am currently doing a project reading Body temperature and pulse sensor that will sent the result wirelessly through XBee.
I started by trying each components separately and everything works fine.
Problem:
Inaccurate result when I combine the XBee and LM35 sensor.
The sensor keep giving the same result. Here's the sketch output.
LM35 Thermometer
Analog in reading: 1023 - Calculated Temp: 109.8
I am very sure that before combining it with XBee everything works just fine.
Can anyone explain to me what's the problem here?
Do it need any voltage adjustment or something?
cutie_lovely_92
Re: Inaccurate result when combining LM35 + XBee
by adafruit_support_bill on Fri Jan 04, 2013 7:43 am
Post a photo showing all your connections. And post the code you are using too.
by cutie_lovely_92 on Fri Jan 04, 2013 1:48 pm
adafruit_support wrote:Post a photo showing all your connections. And post the code you are using too.
#include <SoftwareSerial.h>
SoftwareSerial xbee(2, 3); //RX, TX
int potPin = 0;
float temperature = 0;
void setup()
  Serial.begin(9600);
  Serial.println("LM35 Thermometer ");
  analogReference(INTERNAL);
  xbee.begin(9600);
void printTenths(int value) {
  // prints a value of 123 as 12.3
  Serial.print(value / 10);
  xbee.print(value/10);
  Serial.print(".");
  xbee.print(".");
  Serial.println(value % 10);
  xbee.print(value % 10);
  int span = 20;
  int aRead = 0;
  for (int i = 0; i < span; i++) {
    aRead = aRead+analogRead(potPin);
    aRead = aRead / 20;
    temperature = ((100*1.1*aRead)/1024)*10;
    // convert voltage to temperature
    Serial.print("Analog in reading: ");
    Serial.print(long(aRead));
    // print temperature value on serial monitor
    Serial.print(" - Calculated Temp: ");
    xbee.print(" - Calculated Temp: ");
    printTenths(long(temperature));
    delay(500);
The Xbee connected to PC through Xbee USB shield.
The Xbee shield v1.1 connected to Arduino UNO R3. The LM35 is on the breadboard, mark with red box.
cutie_lovely_92
by adafruit_support_bill on Fri Jan 04, 2013 2:13 pm
Appears to be wired right. But your raw reading is at max scale. You should contact the seller of the LM35.
