How to give delay between sensors
Re: How to give delay between sensors
by cutie_lovely_92 on Mon Jan 07, 2013 3:57 am
odometer wrote:But still, it seems that your code is overzealous in detecting heartbeats.
Maybe your "threshold" is too low.
But even after I try 600-900, the result still the same, it will keep rising until 238.
cutie_lovely_92
by adafruit_support_rick on Mon Jan 07, 2013 10:01 am
I had a look at the pulsesensor website your linked to. Setting thresh to 475 shouldn't cause this problem. However, I would set it back to 512 for now. I think thresh, P, and T should all be initialized to the same number.
Does the pulse sensor work properly if you comment out the call to analogRead(potpin) here?
  for (int i = 0; i < span; i++) {
//    aRead = aRead+analogRead(potPin);
by cutie_lovely_92 on Mon Jan 07, 2013 12:55 pm
driverblock wrote:I had a look at the pulsesensor website your linked to. Setting thresh to 475 shouldn't cause this problem. However, I would set it back to 512 for now. I think thresh, P, and T should all be initialized to the same number.
So I have set it back to 512, try playing around with the loop path by moving the temperature sensor code to work after the pulse sensor works and change the delay to (1000). Seems to be working right but not so accurate and often shows BPM=58. And the LM35 only react to room temperature, it doesn't react to any finger touching which actually should. In this case I have also connect it through XBee module to send the data wirelessly to PC.
Does modifying the delay really has an affect?
Here's the part I modify:
void loop(){
  int span = 20;
  int aRead = 0;
    aRead = aRead + analogRead(potPin);
    aRead = aRead / 20;
    temperature = ((100*5.0*aRead)/1024)*10;   //substitute 5.0V reference for 1.1V reference
    // convert voltage to temperature
    if (QS == true){                       // Quantified Self flag is true when arduino finds a heartbeat
        fadeRate = 255;                  // Set 'fadeRate' Variable to 255 to fade LED with pulse
        Serial.print("\n BPM = ");
        Serial.println(BPM);
        QS = false;                      // reset the Quantified Self flag for next time
        Serial.print("Analog in reading: ");
        Serial.print(long(aRead));
        //print temperature value on serial monitor
        Serial.print(" - Calculated Temp: ");
        xbee.print(" - Calculated Temp: ");
        printTenths(long(temperature));
  ledFadeToBeat();
  delay(1000);                             //  take a break
The result obtained:
Pulse Rate and Body Temperature detector
 BPM = 52
Analog in reading: 56 - Calculated Temp: 27.3
 BPM = 53
 BPM = 53
 BPM = 54
Analog in reading: 57 - Calculated Temp: 27.8
 BPM = 55
 BPM = 56
 BPM = 57
 BPM = 58
 BPM = 58
 BPM = 58
 BPM = 58
 BPM = 58
 BPM = 58
 BPM = 58
 BPM = 58
 BPM = 114
 BPM = 104
 BPM = 96
 BPM = 89
 BPM = 82
 BPM = 77
 BPM = 72
 BPM = 68
 BPM = 64
 BPM = 61
 BPM = 58
 BPM = 58
 BPM = 58
 BPM = 58
 BPM = 58
 BPM = 58
 BPM = 58
 BPM = 58
And here's the new attachment of the circuit.
Xbee module connected to XBee shield v1.1 to Arduino UNO. Also connected with pulse sensor and LM35.
Arduino XBee.jpeg (467.83 KiB) Viewed 614 times
Xbee module connected to PC through XBee Usb adapter
XBee PC.JPG (452.54 KiB) Viewed 614 times
cutie_lovely_92
by adafruit_support_rick on Mon Jan 07, 2013 1:14 pm
cutie_lovely_92 wrote:Does modifying the delay really has an affect?
No. The interrupt reads the pulse sensor every 2 milliseconds, regardless of any delay in loop(). You cannot synchronize the pulse and the temperature readings with a delay().
It is possible that switching back and forth between reading the temperature and reading the pulse is causing inaccurate readings.
Without changing anything else, try these two things:
- comment out the call to readAnalog(potPin), and see if the pulse reading is accurate
- restore the call to readAnalog(potPin), comment out the call to analogRead(pulsePin), and see if the temperature is accurate.
by cutie_lovely_92 on Mon Jan 07, 2013 1:49 pm
1. I restore the code like previous so the code will be
void loop(){
  ledFadeToBeat();
  delay(20);                             //  take a break
  int span = 20;
  int aRead = 0;
    aRead = aRead; //+ analogRead(potPin);
    aRead = aRead / 20;
    // Serial.print("Analog in reading: ");
       // Serial.print(long(aRead));
        //Serial.print(" - Calculated Temp: ");
        //xbee.print(" - Calculated Temp: ");
        //printTenths(long(temperature));
Then I do just like what u asked.
driverblock wrote:
cutie_lovely_92 wrote:- comment out the call to readAnalog(potPin), and see if the pulse reading is accurate
RESULT:
 BPM = 66
 BPM = 67
 BPM = 68
 BPM = 69
 BPM = 70
 BPM = 71
 BPM = 72
 BPM = 74
 BPM = 77
 BPM = 80
 BPM = 85
 BPM = 89
 BPM = 94
 BPM = 99
 BPM = 107
 BPM = 118
 BPM = 129
 BPM = 141
 BPM = 153
 BPM = 164
 BPM = 175
 BPM = 180
 BPM = 188
 BPM = 198
 BPM = 202
 BPM = 207
 BPM = 212
 BPM = 215
 BPM = 210
 BPM = 211
 BPM = 214
 BPM = 220
 BPM = 223
 BPM = 223
 BPM = 217
 BPM = 218
 BPM = 219
 BPM = 219
 BPM = 228
 BPM = 224
 BPM = 224
 BPM = 224
 BPM = 219
 BPM = 219
 BPM = 222
 BPM = 222
 BPM = 216
 BPM = 216
 BPM = 215
 BPM = 218
 BPM = 213
 BPM = 213
 BPM = 211
 BPM = 211
 BPM = 213
Also it only detects every time i put my fingers on it. No continuous heart beat detect.
driverblock wrote:
cutie_lovely_92 wrote:- restore the call to readAnalog(potPin), comment out the call to analogRead(pulsePin), and see if the temperature is accurate.
RESULT:
Analog in reading: 55 - Calculated Temp: 26.8
Analog in reading: 67 - Calculated Temp: 32.7
Analog in reading: 54 - Calculated Temp: 26.3
Analog in reading: 53 - Calculated Temp: 25.8
I put my fingers on the LM35DZ, but the temperature is not affected.
cutie_lovely_92
by adafruit_support_rick on Mon Jan 07, 2013 3:32 pm
Alright, so it works for temperature only, but it doesn't work for pulse only. There must be something wrong with your pulse sensor. You are going to have to talk to the pulse sensor people about that. I can't help you with it.
by cutie_lovely_92 on Mon Jan 07, 2013 3:44 pm
driverblock wrote:Alright, so it works for temperature only, but it doesn't work for pulse only. There must be something wrong with your pulse sensor. You are going to have to talk to the pulse sensor people about that. I can't help you with it.
will try to contact them. Thanks for the guidance so far.
cutie_lovely_92
by miallyrey on Tue Dec 02, 2014 4:37 am
hello, i was experiencing the same problem now, may i ask how did you solved the problem with your bpm reading. thank you
miallyrey
