Winter Storm Juno: Blizzard! ORDERS NOT SHIPPING TODAY. All shipping and UPS service guarantees are suspended due to weather and blizzard conditions.
Adafruit_Fingerprint.cpp Error?
by tomcom on Mon Jan 07, 2013 5:06 pm
Hello
I think I have found a mistake in Adafruit_Fingerprint.cpp.
I have an Arduino Leonardo
On the Leonardo's fingerprint is on pin 2 and pin 3 is not correct.
With Pins 8 and 9, the communication with the fingerprint to work properly.
/ / Pin # 8 is IN from sensor (RED wire)
/ / Pin # 9 is OUT from arduino (WHITE wire)
Serial mySerial software (8, 9);
error:
If no finger on the fingerprint, the Adruino started at the end of the loop again and again.(Reset)
When a finger is scanned, the program runs correctly.
The reason I'm in the
p = uint8_t finger.getImage ();
found
is line 62:
uint8_t Adafruit_Fingerprint :: getImage (void) {
uint8_t packet [] = {FINGERPRINT_GETIMAGE};
to line 62:
uint8_t packet [] = {FINGERPRINT_GETIMAGE, 0x00};
Carry this change, the Arduino runs properly with the fingerprint!
(no reset at the loop-end)
Also change:
is line 82:
uint8_t Adafruit_Fingerprint model :: create (void) {
uint8_t packet [] = {FINGERPRINT_REGMODEL};
to line 82:
uint8_t packet [] = {FINGERPRINT_REGMODEL, 0x00};
Also change:
is line 103:
uint8_t Adafruit_Fingerprint :: empty database (void) {
uint8_t packet [] = {FINGERPRINT_EMPTY};
to line 103:
uint8_t packet [] = {FINGERPRINT_EMPTY, 0x00};
Also change:
is line 135:
uint8_t Adafruit_Fingerprint :: getTemplateCount (void) {
template count = 0xFFFF;
/ / Get number of templates in memory
uint8_t packet [] = {FINGERPRINT_TEMPLATECOUNT};
to line 135:
uint8_t packet [] = {FINGERPRINT_TEMPLATECOUNT, 0x00};
I hope that it serves some users.
much greetings
tomcom
tomcom
Re: Adafruit_Fingerprint.cpp Error?
by adafruit_support_bill on Mon Jan 07, 2013 10:25 pm
This is not a mistake in the code as the code was written for (and works on) standard Arduinos. The Leonardo is quite different from previous Arduinos. Among other incompatibilities, it does not support SoftSerial on all pins.
But thank you for bringing this to our attention. We will make note of this in the tutorial.
http://vort.org/2012/05/25/trouble-soft ... -leonardo/
http://arduino.cc/en/Reference/SoftwareSerial
by tomcom on Tue Jan 08, 2013 5:41 pm
The Code shud by:
uint8_t Adafruit_Fingerprint::getImage(void) {
  uint8_t packet[] = {FINGERPRINT_GETIMAGE, 0x00 };
  writePacket(theAddress, FINGERPRINT_COMMANDPACKET, 3, packet);
  uint8_t len = getReply(packet);
  if ((len != 1) && (packet[0] != FINGERPRINT_ACKPACKET))
   return -1;
  return packet[1];
wenn you have
uint8_t packet[] = {FINGERPRINT_GETIMAGE};
and
return packet[1];
Then you the packet[1] show to NILL!!
Best Greeting
tomcom
tomcom
