Memorial day is 05/25/2015 – Orders will ship out on May 26th. There will not be any deliveries or shipping on Monday. Any order placed after 11am ET on Friday May 22nd will not start to ship out until Tuesday May 26th.
custom icons with GFX libs
by Nevaargh on Sat Jan 26, 2013 3:51 pm
This is being integrated into a sensor display package for my robot. The icons will be arranged visually on my 1.8"tft the same as they are mounted on the robot chassis. I plan to implement simple graphing and other goodies. Maybe even a 3rd dimension to the array to store a differential bitmap for status - flip between the z-axis for on/off or whatever.
Once I have the icons built, I should be able to put status icons with live sensor data anywhere on the screen. Unfortunately, at the moment I have to have a custom icon and function for each icon... and I have to make the icons by hand.
Code has been updated to allow for transparent background ! Code below displays a 'battery'
It'd really be nice to be able to use the output of a tool such as Image2Code natively. :P
// http://learn.adafruit.com/adafruit-gfx-graphics-library/graphics-primitives
// The GFX libs for the 1.8" display.
// the display pins in play
// Pins to use - If you arent using a Mega2560, adjust accordingly
#define sclk 23  // BLUE wire
#define mosi 25  // GREEN wire
#define dc   27  // WHITE wire
#define rst  29  // ORANGE wire - you can also connect this to the Arduino reset
#define cs   31  // YELLOW wire
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library
#include <SPI.h> // not using SPI here so probably don't need this.  Doesn't hurt to have it.
Adafruit_ST7735 tft = Adafruit_ST7735(cs, dc, mosi, sclk, rst);
// Color definitions  These may not be the same colors from the adafruit tutorials (off brand display & LSB/MSB issue?)
    #define BLACK 0x0000
    #define RED 0x001F
    #define REDdk 0xF00F
    #define BLUE 0xF800
    #define GREEN 0x07E0
    #define GREENdk 0x0570
    #define YELLOW 0x07FF
    #define MAGENTA 0xF81F
    #define CYAN 0xFFE0
    #define WHITE 0xFFFF
// a basic icon
// foreground color
int iconBG=0x0000;
// background color
int iconFG=0xFFFF;
// don't draw a pixel - transparent background
int iconTB=0xFFE0; //cyan - it clashes with my intended color scheme
int iconh=12;
int iconw=7;
// const byte icon [iconh] [iconw]
const int icon [12] [7] = {
{iconTB,iconTB,iconFG,iconFG,iconFG,iconTB,iconTB},
{iconTB,iconTB,iconFG,iconBG,iconFG,iconTB,iconTB},
{iconTB,iconFG,iconBG,iconBG,iconBG,iconFG,iconTB},
{iconFG,iconBG,iconBG,iconBG,iconBG,iconBG,iconFG},
{iconTB,iconFG,iconFG,iconFG,iconFG,iconFG,iconTB},
void setup()
  delay(50);
  tft.initR(INITR_REDTAB);   // initialize a ST7735R chip, red tab
  tft.fillScreen(RED);
void loop()
putICON(40,100);
putICON(10,10);
putICON(74,60);
// read the colors from the array and draw the pixel
void putICON(int x, int y){
  int rfoo=0;
  int cfoo=0;
  int r,c;
  for (rfoo=0;rfoo<iconh;)
    for (cfoo=0;cfoo<iconw;)
     if (icon[rfoo][cfoo]!=iconTB) {
       tft.drawPixel(x+cfoo,y+rfoo,icon[rfoo][cfoo]);
     cfoo++;
    rfoo++;
Nevaargh
Re: custom icons with GFX libs
by Nevaargh on Fri Feb 01, 2013 3:57 am
OK, found some useful tools for making the bitmaps, but my display renders them as properly sized/scaled gibberish. Yet my hand-constructed icons are functional - go figure. Working with what I had, I made some simple line-art icons which currently take a number of parameters - linecolor, fillcolor, transparencycolor. 8) Going to add alarmcolor as a variant of linecolor on a trigger value.
Entire display system is Themeable! :P though you will want to define additional colors for your palette.
// note to self:  make the themes a 2D array, then select theme based on timer or event.
//int myTheme [] = {CYAN,GREEN,OLIVE,YELLOW,OLIVE}; // Greens - kinda bright
//int myTheme [] = {CYAN,OLIVE,GREENdk,YELLOW,GREENdk}; // Darker Green
 int myTheme [] = {CYAN,REDdk2,REDdk,YELLOW,REDdk}; // a nice red theme for nighttime
//int myTheme [] = {CYAN,BLUE,BLUEdk1,YELLOW,BLUEGREYdk}; // Da Blues
Sample final code, which I've called RoboShow and include in whole below, renders 12 visual sensor data points in ~1.3 sec on 1.8"tft. Code can likely be optimized. There are dependency libs, but nothing oddball or extremely heavy. SPI, Wire, Adafruit_GFX/ST7735/BMP085, NewPing
PIR (x2)
PING (x2)
Sonar
BMP-temp // selectable F/C display
BMP-alt // selectable f/m display
BMP-bar
ACCEL-x
ACCEL-y
ACCEL-z
Battery // icon/placeholder
So, anyway.
I apologize to everyone who unknowingly contributed, for caught up in the moment as I was I was literally copy/pasting code not expecting it to really work. There is so much of the community in RoboShow, that I believe the code should be set free to mix and mingle with other code-lings as it sees fit.
Do as thou will, harm none.
#include <SPI.h>  // SPI
#include <Wire.h> // Wire
#include <Adafruit_BMP085.h> // BMP - Barometic sensor library
#include <NewPing.h> // NewPing
// the display pins in play - If you arent using a Mega2560 for this, you should be...
int maxdistance=150;
// Ultrasonic-01
int echoPINGright=50;
int triggerPINGright=52; // ping return signal pin
unsigned long triggerVALright=0;
NewPing sonarRight(triggerPINGright,echoPINGright,maxdistance); // NewPing setup of pins and maximum distance.
// Ultrasonic-02
unsigned long echoPINGleft = 24;
unsigned long triggerPINGleft = 22; // Ultrasound signal pin
unsigned long triggerVALleft=0;
NewPing sonarLeft(triggerPINGleft,echoPINGleft,maxdistance); // NewPing setup of pins and maximum distance.
// 3-axis accellerometer uses analog pins
const int xpin = A0;                  // x-axis of the accelerometer
const int ypin = A1;                  // y-axis
const int zpin = A2;                  // z-axis (only on 3-axis models)
const int maxSonarpin = A3; // MaxBotix sonar - EZ
    #define RED 0x001F
    #define REDdk2 0x001A
    #define REDdk 0x000A
    #define BLUE 0xF800
    #define BLUEdk1 0x4101
    #define BLUEGREYdk 0x2101
    #define GREENdk 0x0100
    #define OLIVE 0x0460
    #define CYAN 0xFFE0
// theme colors.   The icons will reference these for outlione, fill and transparency
// int myTheme [] = {colorTRAN,iconCOLR,iconFILL,iconALRM,SENSORGRID};
//int myTheme [] = {CYAN,YELLOW,REDdk,RED,dkRED};
int iconTRAN=myTheme[0]; //cuz it clashes with my intended color scheme - don't draw a pixel - transparent background
int iconCOLR=myTheme[1]; // foreground color
int iconFILL=myTheme[2]; // background color
int iconALRM=myTheme[3]; //
int SENSORGRID=myTheme[4];
int foo=0;
int myInnerDelay=0;
int mydelay=myInnerDelay;
int myOuterDelay=100;
Adafruit_BMP085 bmp;
float RoboShowVer = .04;
void setup()
    Serial.begin(115200); // Open serial monitor at 115200 baud to see ping results.
    delay(myInnerDelay);
    tft.setTextColor(iconCOLR,iconFILL);
    tft.setTextSize(0);
    tft.fillScreen(BLACK);
//  initRoboShow(COLOR,float,wait time in sec);
    initRoboShow(SENSORGRID,RoboShowVer,5);
     //tft.initR(INITR_REDTAB);   // initialize a ST7735R chip, red tab
    //tft.fillScreen(BLACK);
void loop()
  // in general:  foo(x,y,sensorval);
//  putPIR(25,45,23);
//  putPIR(105,45,2);
//  putPING(35,60, 200);
//  putPING(75,60, 200);
  unsigned int uSLeft = sonarLeft.ping();
  unsigned int uSRight = sonarRight.ping();
  iconPIRshow(10,35,0); // x,y,value
  iconPIRshow(105,35,0); // x,y,value
  iconPINGshow(35,60,(uSLeft/US_ROUNDTRIP_CM)); // x,y,value
  iconPINGshow(75,60,(uSRight/US_ROUNDTRIP_CM)); // you get the idea
  putBMPalt(35,90,'F'); // 'F' for Farenheight, 'C' for Celsius
  putMAXsonar(5,100);
  putBMPtemp(5,120,'F'); // 'F' for Feet, 'M' for Meters
  putACCEL(60,120);
  putBMPbar(5,140);
  iconBATTshow(118,145,50); // bottom right of 1.8"tft
// PIR Display
int iconPIRh=12;
int iconPIRw=16;
// const byte icon [h] [w]
const int iconPIR [12] [16] = {
{iconCOLR,iconTRAN,iconCOLR,iconTRAN,iconTRAN,iconCOLR,iconTRAN,iconTRAN,iconCOLR,iconTRAN,iconCOLR,iconTRAN,iconTRAN,iconCOLR,iconTRAN,iconCOLR},
{iconTRAN,iconCOLR,iconTRAN,iconTRAN,iconCOLR,iconTRAN,iconTRAN,iconCOLR,iconTRAN,iconTRAN,iconTRAN,iconCOLR,iconTRAN,iconTRAN,iconCOLR,iconTRAN},
{iconTRAN,iconTRAN,iconCOLR,iconTRAN,iconTRAN,iconCOLR,iconTRAN,iconTRAN,iconCOLR,iconTRAN,iconCOLR,iconTRAN,iconTRAN,iconCOLR,iconTRAN,iconTRAN},
{iconTRAN,iconTRAN,iconTRAN,iconCOLR,iconTRAN,iconTRAN,iconTRAN,iconCOLR,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconCOLR,iconTRAN,iconTRAN,iconTRAN},
{iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconCOLR,iconTRAN,iconTRAN,iconTRAN,iconCOLR,iconTRAN,iconTRAN,iconCOLR,iconTRAN,iconTRAN,iconTRAN,iconTRAN},
{iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN},
{iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN},
{iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconCOLR,iconFILL,iconFILL,iconFILL,iconFILL,iconFILL,iconFILL,iconCOLR,iconTRAN,iconTRAN,iconTRAN,iconTRAN},
{iconTRAN,iconTRAN,iconTRAN,iconCOLR,iconFILL,iconFILL,iconFILL,iconFILL,iconFILL,iconFILL,iconFILL,iconFILL,iconCOLR,iconTRAN,iconTRAN,iconTRAN},
{iconTRAN,iconTRAN,iconTRAN,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconTRAN,iconTRAN,iconTRAN},
void iconPIRshow(int x, int y,int sensorval){
  int rfoo=0;
  int cfoo=0;
  int r,c;
  for (rfoo=0;rfoo<iconPIRh;)
    for (cfoo=0;cfoo<iconPIRw;)
     if (iconPIR[rfoo][cfoo]!=iconTRAN) {
       tft.drawPixel(x+cfoo,y+rfoo,iconPIR[rfoo][cfoo]);
     cfoo++;
    rfoo++;
  tft.setTextSize(0);
  tft.fillRect(x, y+rfoo+2, cfoo, 11, iconFILL);
  tft.drawRect(x, y+rfoo+2, cfoo, 11, iconCOLR);
  tft.setCursor(x+3, y+rfoo+4);
  tft.print(sensorval);
// PING Display
int iconPINGh=10;
int iconPINGw=21;
const int iconPING [10] [21] = {
//FLASH_TABLE(byte, iconPING, 21,
{iconTRAN,iconTRAN,iconTRAN,iconCOLR,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconCOLR,iconTRAN,iconTRAN,iconTRAN,iconCOLR,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconCOLR,iconTRAN,iconTRAN,iconTRAN},
{iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconCOLR,iconTRAN,iconTRAN,iconCOLR,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconCOLR,iconTRAN,iconTRAN,iconCOLR,iconTRAN,iconTRAN,iconTRAN,iconTRAN},
{iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconCOLR,iconCOLR,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconCOLR,iconCOLR,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN},
{iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN,iconTRAN},
{iconTRAN,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconTRAN},
{iconCOLR,iconCOLR,iconFILL,iconFILL,iconCOLR,iconFILL,iconFILL,iconCOLR,iconFILL,iconFILL,iconCOLR,iconFILL,iconFILL,iconCOLR,iconFILL,iconFILL,iconCOLR,iconFILL,iconFILL,iconCOLR,iconCOLR},
{iconCOLR,iconFILL,iconFILL,iconFILL,iconFILL,iconFILL,iconFILL,iconFILL,iconFILL,iconFILL,iconFILL,iconFILL,iconFILL,iconFILL,iconFILL,iconFILL,iconFILL,iconFILL,iconFILL,iconFILL,iconCOLR},
void iconPINGshow(int x, int y,int sensorval){
  int rfoo=0;
  int cfoo=0;
  int r,c;
  for (rfoo=0;rfoo<iconPINGh;)
    for (cfoo=0;cfoo<iconPINGw;)
     if (iconPING[rfoo][cfoo]!=iconTRAN) {
       int myPixel=iconPING[rfoo][cfoo];
       tft.drawPixel(x+cfoo,y+rfoo,myPixel);
     cfoo++;
    rfoo++;
  tft.setTextSize(0);
  tft.fillRect(x-1, y+rfoo+2, cfoo+2, 11, iconFILL);
  tft.drawRect(x-1, y+rfoo+2, cfoo+2, 11, iconCOLR);
  tft.setCursor(x+2, y+rfoo+4);
// BATTERY Display
int iconBATTh=12;
int iconBATTw=7;
const int iconBATT [12] [7] = {
{iconTRAN,iconTRAN,iconCOLR,iconCOLR,iconCOLR,iconTRAN,iconTRAN},
{iconTRAN,iconTRAN,iconCOLR,iconFILL,iconCOLR,iconTRAN,iconTRAN},
{iconTRAN,iconCOLR,iconFILL,iconFILL,iconFILL,iconCOLR,iconTRAN},
{iconCOLR,iconFILL,iconFILL,iconFILL,iconFILL,iconFILL,iconCOLR},
{iconTRAN,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconCOLR,iconTRAN},
void iconBATTshow(int x, int y,int sensorval){
  int rfoo=0;
  int cfoo=0;
  int r,c;
  for (rfoo=0;rfoo<iconBATTh;)
    for (cfoo=0;cfoo<iconBATTw;)
     if (iconBATT[rfoo][cfoo]!=iconTRAN) {
       tft.drawPixel(x+cfoo,y+rfoo,iconBATT[rfoo][cfoo]);
     cfoo++;
    rfoo++;
  tft.setTextSize(0);
  tft.setCursor(x-15, y+3);
// PING sensor display - linedraw method
//void putPING(int x,int y, int sensorval) {
//  tft.setTextSize(0);
//  tft.setCursor(x+2, y+2);
//  tft.fillRect(x, y, 22, 12, iconFILL);
//  tft.drawRect(x, y, 22, 12, iconCOLR);
//  tft.print(sensorval);
// PIR sensor display - LineDraw method
//void putPIR(int x,int y, int sensorval) {
//  int raysize=15;
//  tft.setCursor(x-4, y-13);
//  tft.fillTriangle(x, y, x-raysize , y-raysize ,x+raysize ,y-raysize, iconFILL);
//  tft.drawTriangle(x, y, x-raysize , y-raysize ,x+raysize ,y-raysize, iconCOLR);
// BMP - Barometer, Temp, Altimeter
void putBMPtemp(int x,int y,char myUnit) {
    tft.setTextSize(0);
    if (!bmp.begin()) {
   Serial.println("Could not find a valid BMP085 sensor, check wiring!");
   while (1) {}
    float tc=bmp.readTemperature();
    float tf=tc*9/5+32;
    tft.fillRect(x, y, 50, 11, iconFILL);
    tft.drawRect(x, y, 50, 11, iconCOLR);
    tft.setCursor(x+3, y+2);
    if (myUnit=='F') {
      tft.print(tf);
      tft.println("F");
    } else {
      tft.print(tc);
      tft.println("C");
// Display Altimeter data
void putBMPalt(int x,int y,char myUnit) {
    tft.setTextSize(0);
    tft.setCursor(x, y);
    if (!bmp.begin()) {
   while (1) {}
    float am=bmp.readAltitude();
    float af=am*3.280839895;
    float amr=bmp.readAltitude(101500);
    float afr=amr*3.280839895;
    tft.fillRect(x, y, 70, 11, iconFILL);
    tft.drawRect(x, y, 70, 11, iconCOLR);
    if (myUnit=='F') {
      tft.print(afr);
      tft.println("ft");
    } else {
      tft.print(amr);
      tft.println("m");
void putACCEL(int x,int y) {
  tft.setTextSize(0);
  tft.fillRect(x, y, 35, 32, iconFILL);
  tft.drawRect(x, y, 35, 32, iconCOLR);
  tft.print("x:");
  tft.print(analogRead(xpin));
  tft.setCursor(x+3, y+12);
  tft.print("y:");
  tft.print(analogRead(ypin));
  tft.setCursor(x+3, y+22);
  tft.print("z:");
  tft.print(analogRead(zpin));
void putMAXsonar(int x,int y) {
    int sensoravg=6;
    int distsensor=0; // maxbotix sonar value initialize
    int i;
    for (i=0; i<sensoravg; i++) {
     distsensor += analogRead(maxSonarpin);
     // delay(50);
  distsensor /= sensoravg;
  tft.setTextSize(0);
  tft.fillRect(x, y, 25, 12, iconFILL);
  tft.drawRect(x, y, 25, 12, iconCOLR);
  tft.print(distsensor);
  tft.print("cm");
void putBMPbar(int x,int y) {
    tft.setTextSize(0);
    if (!bmp.begin()) {
   while (1) {}
    float pa=bmp.readPressure();
      tft.print(pa,0);
      tft.println("pa");
// Show the RoboShow ver# and init the grid.
void initRoboShow(uint16_t color,float ver,int waitforsensors) {
  putGrid(SENSORGRID);
  tft.setCursor(23,3);
  tft.setTextColor(YELLOW);
  tft.print("RoboShow v");
  tft.print(RoboShowVer);
  if (waitforsensors>0) {
    tft.setCursor(3,100);
    tft.print("... initializing ...");
    tft.setCursor(3,110);
    tft.print(  "...    sensors   ...");
    tft.fillRect(35, 130, 60, 12, iconFILL);
    tft.drawRect(35, 130, 60, 12, iconCOLR);
    tft.setCursor(40,132);
    // insert a proper counter
    tft.print("cntr:");
    tft.print((waitforsensors/1000));
    tft.print("s");
    delay(waitforsensors*1000);
// the grid for the background
void putGrid(int gridcolor) {
  for (int16_t y=0; y < tft.height(); y+=6) {
    tft.drawFastHLine(0, y, tft.width(), gridcolor);
  for (int16_t x=0; x < tft.width(); x+=6) {
    tft.drawFastVLine(x, 0, tft.height(), gridcolor);
Nevaargh
