WS2801 Broken LED?
WS2801 Broken LED?
by edc1591 on Thu Jan 31, 2013 10:29 pm
I have the WS2801 pixels (http://www.adafruit.com/products/322) and one of the LEDs appears to not be working correctly. It seems like it's not receiving commands from the Arduino. Sometimes it doesn't turn on at all, and if it does turn on, it gets stuck on that color until I disconnect power from the LEDs. All other LEDs work fine, its just one that's not working.
edc1591
Re: WS2801 Broken LED?
by pburgess on Fri Feb 01, 2013 1:38 am
Hi there,
Is the wonky pixel in the middle of the strand or at the end?
Well regardless...try giving the affected pixel a firm squeeze (flat against the embedded PCB inside), see if that changes the outcome. If that helps, it may simply be a questionable solder connection inside, which can be touched up. Otherwise, we can arrange for a replacement.
pburgess
by edc1591 on Fri Feb 01, 2013 11:48 am
The broken LED is in the middle. And squeezing seems to have no effect.
edc1591
by pburgess on Fri Feb 01, 2013 8:23 pm
Alrighty, please email support@adafruit.com, and include both your order number and a link to this post. We'll get a replacement out to you asap!
pburgess
by edc1591 on Fri Feb 01, 2013 9:52 pm
Great, thanks!
edc1591
