Controlling a ducted fan
by ewokkillah on Wed Feb 06, 2013 4:31 pm
Hi There,
I'm trying to control a ducted fan with a brushless motor. What I want to have it do is when i press a button have it go full speed. I tryed modifying an existing sketch that sweeps the speed of the motor up and down, but I cant seem to get it to work. so any help or advice would be greatly appreciated.
This is a copy of the sketch I'm working from:
[code#] include <Servo.h>
Servo myservo;
void arm(){
// arm the speed controller, modify as necessary for your ESC
Serial.println("arming");
setSpeed(30);
delay(2000);
setSpeed(90);
delay(2000);
Serial.println("armed");
setSpeed(30);
delay(2000);
void setSpeed(int speed){
// speed is from 0 to 100 where 0 is off and 100 is maximum speed
//the following maps speed values of 0-100 to angles from 0-180,
int angle = map(speed, 0, 100, 0, 180);
myservo.write(angle);
void setup()
Serial.begin(115200);
myservo.attach(9);
arm();
void loop()
int speed;
Serial.println("Sweeping up");
for(speed = 37; speed <= 90; speed += 1) {
setSpeed(speed);
Serial.println(speed);
delay(100);
setSpeed(30);
delay(1000);
Serial.println("Sweeping down");
for(speed = 90; speed > 37; speed -= 1) {
setSpeed(speed);
delay(100);
Serial.println("30 halting...");
setSpeed(30);
delay(5000);
} [/code]
ewokkillah
Re: Controlling a ducted fan
by adafruit_support_bill on Wed Feb 06, 2013 7:17 pm
Does the sweep sketch work? I don't see any button code. What have you tried that didn't work.
by ewokkillah on Wed Feb 06, 2013 8:31 pm
thanks for your reply. That's the original sketch it works to sweep the motor speed up and down.
this is my modification
[code:banned]
#include <Servo.h>
Servo myservo;
int switchPin = 8;
void arm(){
setSpeed(30);
delay(2000);
setSpeed(90);
delay(2000);
setSpeed(30);
delay(2000);
void setup()
myservo.attach(9);
pinMode(switchPin, INPUT);
arm();
void loop()
int speed;
Serial.println("GO");
if (digitalRead(switchPin) == HIGH);
setSpeed(90);
delay(4000);
Serial.println("STOP");
if (digitalRead(switchPin) == LOW);
setSpeed(0);
delay(100);
setSpeed(30);
delay(5000);
[/code:banned]
It turns the motor on full speed then off, but no button functionality.
thanks.
ewokkillah
by adafruit_support_bill on Wed Feb 06, 2013 10:22 pm
What do you see in the serial monitor? Post the output.
by ewokkillah on Thu Feb 07, 2013 6:06 pm
arming
armed
GO
STOP
30 halting...
GO
STOP
30 halting...
GO
STOP
30 halting...
GO
STOP
30 halting...
GO
STOP
30 halting...
GO
STOP
30 halting...
ewokkillah
by adafruit_support_bill on Thu Feb 07, 2013 7:43 pm
How do you have your switch wired? Are you using a pullup or pulldown resistor?
by ewokkillah on Thu Feb 07, 2013 11:28 pm
Yes a 10k pull down resistor on the ground
ewokkillah
by adafruit_support_bill on Fri Feb 08, 2013 7:09 am
Get rid of the semicolons at the end of your 'if' statements. Those are statement 'terminators' so the code after the 'if' is not conditional.
http://arduino.cc/en/Reference/If
by ewokkillah on Sat Feb 09, 2013 4:16 am
That did the trick :D
Thanks.
ewokkillah
by ewokkillah on Sun Feb 10, 2013 1:01 am
i think I jumped the gun a little. There still seems to be a bug somewhere it doesn't work consistently. Sometimes I press the button the fan turns on, and sometimes no.
any Ideas?
ewokkillah
by adafruit_support_bill on Sun Feb 10, 2013 8:13 am
You have a lot of delays in your code. If you press the button during a delay, it won't be seen.
