Adafruit Ultimate GPS Breakout echo code
by aarballer7 on Fri Feb 08, 2013 9:53 am
I downloaded the echo code from the GPS library provided. I tried to verify the code and upload it but it is returning errors as follows.
echo:38: error: 'Adafruit_GPS' does not name a type
echo.pde: In function 'void setup()':
echo:61: error: 'GPS' was not declared in this scope
echo:66: error: 'PMTK_SET_NMEA_OUTPUT_RMCGGA' was not declared in this scope
echo:76: error: 'PMTK_SET_NMEA_UPDATE_5HZ' was not declared in this scope
echo.pde: In function 'void __vector_14()':
echo:90: error: 'GPS' was not declared in this scope
If anyone has some insight into what declarations need to be made, that would be great, thanks.
I am using an Arduino UNO , and ultimate GPS Breakout v3.
Thanks.
aarballer7
Re: Adafruit Ultimate GPS Breakout echo code
by WethaGuy on Sat Feb 09, 2013 9:08 pm
It looks like you haven't installed the Adafruit_GPS library (saved it in the right directory under your Arduino directory). Go here and download the library and follow the directions in the readme on where to install it.
Good luck.
WethaGuy
by aarballer7 on Sun Feb 10, 2013 4:01 pm
Alright thanks, this code is no longer in error but I am getting an error
avrdude: stk500_getsync(): not in sync: resp= 0x00
any insight?
aarballer7
cron
