Fingerprint scanner
Fingerprint scanner
by lawrencefla on Sat Mar 02, 2013 3:16 pm
Hello, I bought the fingerprint scanner from adafruit but I am currently having issues with opening it via the SFG Demo. When I click the open device and select the com port for the arduino board I receive an open device error. After trying a few more times I was finally able to scan a fingerprint 2 times but kept receiving the "Enrollment error scan again" notification after about the 3rd attempt the light on the scanner does not come on again even though I was prompted to place finger on scanner. Please note:
1. I am using windows 8.
2. I have Soldered the wires from the fingerprint scanner to thicker wires to increase connectivity.
3. The Open device error comes on after a few attempts.
lawrencefla
Re: Fingerprint scanner
by adafruit_support_bill on Sun Mar 03, 2013 7:44 am
How are you powering the scanner? Post a photo showing all your connections.
by lawrencefla on Tue Mar 05, 2013 5:36 pm
White wire= Pin 0
Green Wire= Pin 1
Black wire= Gnd
Red wire = 5v
Pic1
Pic 2
lawrencefla
by lawrencefla on Tue Mar 05, 2013 5:40 pm
also as of now after clicking open device in the SFG demo software after awhile it finally finds the device but when promptied to place finger on scanner the light on the scanner does not come on.
lawrencefla
by adafruit_support_bill on Wed Mar 06, 2013 6:43 am
Can you post the device information displayed by SFG Demo when the device is connected?
by ratheeshbr on Wed Mar 06, 2013 9:02 pm
I am using adafruit/Adafruit-Fingerprint-Sensor-Library for interfacing with arduino. I am getting an ID in which I have stored the template from the scanner. Is it possible to get a value representing the image taken by the scanner? I am having two finger print scanners and I have to get the same value out for the same finger from both sensors. Is it possible to get?
ratheeshbr
by adafruit_support_bill on Thu Mar 07, 2013 6:22 am
@ratheeshbr - please start a new topic for your question.
by lawrencefla on Tue Mar 12, 2013 1:24 pm
Here it is. After about ten tries of just keep clicking the Open Device (0) button it finally found the scanner but when prompted to place finger on scanner the light did not come on so I waited about 8minutes and the light to the scanner finally came on and I was able to enroll a fingerprint but had to wait another 8min to scan the other. When I tried to do the process over again another day no matter how many times I clicked the Open Device button I would continuously receive the "Open device, fail" error
lawrencefla
by lawrencefla on Tue Mar 12, 2013 1:27 pm
Sorry last pic did not come out full
lawrencefla
by adafruit_support_bill on Tue Mar 12, 2013 4:12 pm
If it 'sometimes' works, the baud-rate must be OK. Must be just a flakey sensor. If you contact support@adafruit.com with a link to this thread they can arrange a replacement for you.
