motor with pwm forward and reverse help
by Dsr122076 on Sun Mar 03, 2013 4:07 pm
OK I purchased an RF 4ch relay board in order to make the motors go forward and reverse. However, The motors are high speed and I need to slow them down. I have 4 PWM available. My question is: Do i need to just put one PWM per motor on the + line? or do I need one on each + and - line because the motor will be reversed?
Sorry I am a noob at this.
Dsr122076
Re: motor with pwm forward and reverse help
by adafruit_support_bill on Sun Mar 03, 2013 4:13 pm
Hard to say without knowing anything about the relay board. It usually takes at least two relays to do forward/reverse control of a motor.
These days most people use a solid-state H-bridge like the ones in the MotorShield. http://www.adafruit.com/products/81
by Dsr122076 on Sun Mar 03, 2013 4:36 pm
this is the relay board I found. I purchased it before finding out about adafruit:
4 Relay CH DC12V Wireless Receiver&Transmitter Momentary Toggle Latched RF Remote Control Switch System LED SMD ON OFF
http://www.aliexpress.com/item/4-Relay- ... 43990.html
The issue is I need to have it controlled by a keyfob which is why I had that board. So the RF portion of the board I have is crucial.
I also purchased the https://www.adafruit.com/products/1096-- received this one much faster but even when there is 9 v on the activated line the motor will not turn in either direction.
Dsr122076
