using interrupt pin 20 on Mega
by sgtserg on Mon Mar 04, 2013 12:48 am
I read that the arduino mega has four interrupt pins. I wanted to use pins 20-21, but these pins are also used for I2C. I tried writing a simple code to test the interrupt using these pins but no luck. When I used pin 19 it worked fine. I'm wondering if the reason that these pins are not working is because I need to declare these pins to be for interrupt. Thanks.
sgtserg
Re: using interrupt pin 20 on Mega
by adafruit_support_bill on Mon Mar 04, 2013 8:16 am
You need to use the AttachInterrupt() function. Interrupt pins on the Mega are: 2, 3, 21, 20, 19, 18
http://arduino.cc/en/Reference/AttachInterrupt
You can also use pin-change interrupts on pins 10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69
http://playground.arduino.cc/Main/PinChangeInt
