Cross Fading LEDs
Cross Fading LEDs
by fredk1 on Wed Mar 06, 2013 12:00 am
I'm very new to this so please excuse such a basic question.... I'm trying to cross fade a RGB LED using 3 PWM pins. I am using a "for" statement within a for statement and it cross fades smoothly within the loop. But when it jumps back to the top of the loop I get a visual pulse in the LED. Any suggestions? Thanks for the help. Here's the code:
#define LED 9 //the pin for the LED
#define LED2 10 //the pin for the LED
#define LED3 11//THe last pin
int n = 0; //counting up and down
int i = 0; //we'll use this to count up and down
int w = 0;
  pinMode(LED, OUTPUT); //tell a LED is an output
  pinMode(LED2, OUTPUT);
  pinMode(LED3, OUTPUT);
  for(n = 255; n > 1; n--) { //loop from 0 to 254 (fade out)
  analogWrite(LED, n); //set the LED brightness
  for(i = 0; i < 255; i++);//Fade in
  analogWrite(LED2, i);
  delay (10);
  for(i = 255; i > 1; i--) { //loop from 0 to 254 (fade out)
  analogWrite(LED2, i); //set the LED brightness
  for(w = 0; w < 255; w++);//Fade in
  analogWrite(LED3, w);
  delay (10);
  for(w = 255; w > 1; w--) { //loop from 0 to 254 (fade out)
  analogWrite(LED2, w); //set the LED brightness
  for(n = 0; n < 255; n++); //Fade in
  delay (10);
Last edited by adafruit_support_rick on Wed Mar 06, 2013 8:57 am, edited 1 time in total.
Reason: please use [CODE] tags
fredk1
Re: Cross Fading LEDs
by adafruit_support_rick on Wed Mar 06, 2013 9:02 am
You reset the LED in the inner loop from 255 back to zero each time through the output loop. Is this the pulse you're referring to?
    for(i = 0; i < 255; i++);//Fade in    //RESET LED2 TO 0 AND FADE IN
  delay (10);
Maybe you want something more like this?
    analogWrite(LED2, (255-n));  //set LED2 brightness as the complement of LED
    delay (10);
by fredk1 on Wed Mar 06, 2013 11:10 am
Thanks for helping me with the "code" tab.
As to your comment, I start LED (blue) at full brightness and then dim it down at the beginning of the loop. As it fades down, LED2 (green) fades in. Visually this is a smooth transition, as is the fade down of LED2 (green) and the fade up of LED3 (red). The LED3 fade down is also smooth as is the fade back up of LED (blue) at the end of the loop. At the end of the loop, LED should be back at 255, full brightness. The visual pulse happens when it goes back to the beginning of the loop, blue pulses on and off again. So I guess my question is, when the sketch runs, does it loop through the "loop" only, or does it loop through the entire sketch? (Then I would be resetting LED to 0.) Could it also be just a poor use of the "for" condition? Any help would be greatly appreciated. This is the first step in a larger project.
Thanks.
fredk1
by adafruit_support_bill on Wed Mar 06, 2013 11:23 am
You have a nested 'for' loop, but the inner loop is empty, all it does is count up to 255:
  delay (10);
The scope of this loop:
is bounded by the semicolon. So it does no fading. It just leaves 'n' at 255, so this line:
causes a flash.
by fredk1 on Wed Mar 06, 2013 11:37 am
Thanks! I really appreciate it!
fredk1
by fredk1 on Wed Mar 06, 2013 3:34 pm
So maybe something a little more like this?
  analogWrite(LED_red, w); //set the LED brightness
  for(n = 0; n < 255; n++){
  analogWrite(LED_blue, n);
  delay (10);
fredk1
by adafruit_support_bill on Wed Mar 06, 2013 5:32 pm
I don't think you even need the nested loop. For a cross fade, I think you want something like:
  for(i = 0; i < 256; i++)
    analogWrite(LED_red, 255-i);          //red led fades out
    analogWrite(LED_blue, i);  // blue led fades in
    delay (10);
by fredk1 on Wed Mar 06, 2013 5:57 pm
Cool. And I really appreciate the help. If you can't tell, I'm learning to code at the same time as learning Arduino.
fredk1
by fredk1 on Wed Mar 06, 2013 9:24 pm
Just ran the code. My solution was functional but still jumpy. Yours was silky smooth. Thanks again.
fredk1
