Problem with ST7565 and SdCard
by ttfte on Thu Mar 28, 2013 7:44 am
Hello!
We are useing the Display Lib ST7565, and we want to use the Sd Card parallel to the Display!
but we have a problem, how can we make the slave select with this display lib.
at the moment de Display crashed when we start log on the Sd Card!
The measurement Values are stored on the SD card but the display disappears!
Our Microcontroller are ATmega90USB1286, (Teensy 2.0++)!
We are programming in ARDUINO!
ttfte
Re: Problem with ST7565 and SdCard
by franklin97355 on Thu Mar 28, 2013 12:07 pm
You need to make sure your slave select line is different for each device, it sounds like it is not. I can't tell more as I don't know your code or connections.
franklin97355
by ttfte on Fri Mar 29, 2013 12:44 pm
Here is the part of our Sourcecode:
#include <DateTimeStrings.h>
#include <DateTime.h>
#include "ST7565.h"
#include <avr/sleep.h>
#include <ST7565_Menu.h>
#include <SD.h>
File file;
const int ledPin    = 6;   // Teensy has LED on 11, Teensy++ on 6
ST7565 glcd(22, 21, 27, 26, 24 );  // SPI //on these Pins our Display and SD-Card are connected!
//Slave Select for "SD-Card" are Pin 20 and Slave Select for "Display" are Pin 24!
float Current_O2;
    void loop()
           WriteSd();
    void WriteSd()
        if (Sd_on_off == true)
            if (SD.begin())
                  file = SD.open("Test_O2.txt", FILE_WRITE);
                  file.println(Current_O2); // thats a measurement Value
                  file.print(time_is);
                  file.close();
I hope you can to help us further! :)
Last edited by adafruit_support_bill on Fri Mar 29, 2013 1:18 pm, edited 1 time in total.
Reason: Please use the 'code' button when submitting code
ttfte
by adafruit_support_bill on Fri Mar 29, 2013 1:21 pm
Where are you setting that for the SD?
by ttfte on Fri Mar 29, 2013 2:39 pm
We have also tried "SD.begin(20);"
with the information from these two sites:
http://arduino.cc/en/Reference/SD
http://arduino.cc/en/Reference/SDbegin
it still does not work!
ttfte
by adafruit_support_bill on Fri Mar 29, 2013 2:55 pm
You might try contacting the Teensy engineers over at http://www.pjrc.com/
