Troubleshooting! help with avrdude: stk500_getsync(): not in sync: resp=0x00
by Faye_V on Sun Mar 31, 2013 5:50 pm
Hi Adafruit support,
I was reading a locked topic about this error cause I got the same:
I'm working with an Arduino UNO Rev3 board and everything was going ok until my sketchs would no longer upload because of this error. What could have caused this error?
- I checked the serial COM port and it's the correct port
- The Rx and Tx lights don't flash when "uploading" message is shown
- I tried hard resetting the board shorting briefly RESET pin and GND and didn't work either
- I tried uploading ArduinoISP sketch, same message
- Already tried with a new USB cable, doesn't work either
All of the above is done while nothing is connected to the board but the USB cable.
How can I solve this? Please if someone solved it, help me with this, thanks!
Faye_V
Re: Troubleshooting! help with avrdude: stk500_getsync(): not in sync: resp=0x00
by adafruit_support_bill on Mon Apr 01, 2013 5:44 am
Do you see any led activity when the upload starts or when you open the Serial Monitor?
by Faye_V on Mon Apr 01, 2013 11:10 am
The only led activity I see is ON led and L led (green and orange) on, but no blinking. Could this be because of a damaged bootloader?
If so, how does a bootloader stops working? Is there a way to upload a bootloader again?
Thank you for your response!
Faye_V
by adafruit_support_bill on Mon Apr 01, 2013 12:57 pm
Do you see any led activity when you press the reset button?
by Faye_V on Wed Apr 03, 2013 10:52 am
When I press the reset button L (orange led) blinks.
Faye_V
by adafruit_support_bill on Wed Apr 03, 2013 1:26 pm
That means that your bootloader is OK.
It sounds like the problem is in the 16U2 chip that handles the USB/Serial interface. Some people have had revived their boards by re-flashing the 16U2 chip. See here for details: viewtopic.php?f=25&t=25146#p129582
by Faye_V on Wed Apr 03, 2013 3:58 pm
Thank you a lot, I'll try that solution!
Why could that happen? So I can avoid having the same problem again..
Faye_V
by adafruit_support_bill on Wed Apr 03, 2013 4:14 pm
Not sure. We have never experienced that phenomenon here - and I haven't heard a good explanation of it either.
by Faye_V on Fri Apr 05, 2013 9:05 am
Oh I see.. So I tried following the steps shown on the Arduino page, but my board won't reset when I shortcircuit the two pins that stick out closest to the USB serial port. I got stuck there, how can I DFU reset my board?
Faye_V
by adafruit_support_bill on Fri Apr 05, 2013 10:42 am
but my board won't reset .
Do you mean the board or the 16U2? Does the Uno still show up as a serial device?
As I said, we haven't encountered this problem firsthand, so our knowledge of it is only from what we have read. This site has the most detailed reset procedure I have seen so far: https://www.virtuabotix.com/?p=673
by wag4803055 on Mon Apr 29, 2013 2:00 pm
I have this problem, also, but only when using the Arduino as the programmer. When I use my AVRTinyISP uploads work just fine. My arduino board beagn with me as one with a fried processor, which I replaced with a sample. I downloaded all of the Arduino environment and drivers, purchased and used a AVRTinyISP to upload the Boot Loader. After which I uploaded the Blink program, all using the 6 pin ISP connection. But when I the attempt upload using the onboard USB interface I get the red message shown in the subject line, above. I worked to finally get the serial port to be correct, but the upload still fails. Everything about the setup, drivers, etc. is correct. Then I saw a mention in a post of enabling the use of verbose output during upload and the shift ket while pushing the upload button. The only strange thing that appears in the verbose output is the message of "overriding baud rate :19200". This is odd because I know that the COM channel is set to 9600. It would appear that the arduino environment is searching for an understandable response from the board during upload and it's changing the baud rate to do so. I imagine when it gets a response, ascii characters, but does not recognize them, it quits, printing the avrdude stk500... message. It could be that the serial input pin on the FTDI chip is blown, probably during the same event that fried the processor, also hit the FTDI chip, but limited only to the serial input pin. Pleas give you comments if this diagnosis makes sense or not. meanwhile I will try ti get a replacement FTDI chip.
wag4803055
by adafruit_support_bill on Mon Apr 29, 2013 4:42 pm
It would help to give us at least some some basic information.
    What kind of Arduino?
    What bootloader is on the chip?
    What board-type are you setting in the IDE?
    What is the diagnostic output when you try to upload?
by Sanborn on Sun May 05, 2013 5:08 pm
I have this same problem with my Uno and IDE 1.5.2.
I can program the Uno a few times but then BAM I get the same error as the OP. If I uninstall the Arduino Uno from Device Manager and reinstall the problem will reset.
I'm fairly certain this is a Win8 64-bit problem for me, can the OP confirm what their OS is?
Sanborn
