Error w/ Adafruit GPS Library & GSM Library together
Joshua_J0
Re: Error w/ Adafruit GPS Library & GSM Library together
Post by Joshua_J0 »
I tried that, but I still get these errors:
parsing.ino: In function 'void loop()':
parsing:47: error: too many arguments to function 'float conv_coords(float)'
parsing:166: error: at this point in file
parsing:168: error: at this point in file
adafruit_support_rick
Post by adafruit_support_rick »
The following compiles for me:
// Test code for Adafruit GPS modules using MTK3329/MTK3339 driver
// This code shows how to listen to the GPS module in an interrupt
// which allows the program to have more 'freedom' - just parse
// when a new NMEA sentence is available! Then access data when
// desired.
// Tested and works great with the Adafruit Ultimate GPS module
// using MTK33x9 chipset
//    ------> http://www.adafruit.com/products/746
// Pick one up today at the Adafruit electronics shop
// and help support open source hardware & software! -ada
#include <Adafruit_GPS_Alt.h>
#include <AltSoftSerial.h>
// If you're using a GPS module:
// Connect the GPS Power pin to 5V
// Connect the GPS Ground pin to ground
// If using software serial (sketch example default):
//   Connect the GPS TX (transmit) pin to Digital 3
//   Connect the GPS RX (receive) pin to Digital 2
// If using hardware serial (e.g. Arduino Mega):
//   Connect the GPS TX (transmit) pin to Arduino RX1, RX2 or RX3
//   Connect the GPS RX (receive) pin to matching TX1, TX2 or TX3
// If using AltSoftSerial, keep this line enabled
// Modify the shield with a jumper wire from RX to Digital Pin 9
AltSoftSerial mySerial;
Adafruit_GPS_Alt GPS(&mySerial);
// If using hardware serial (e.g. Arduino Mega), comment
// out the above six lines and enable this line instead:
//Adafruit_GPS GPS(&Serial1);
// Set GPSECHO to 'false' to turn off echoing the GPS data to the Serial console
// Set to 'true' if you want to debug and listen to the raw GPS sentences.
#define GPSECHO  true
// this keeps track of whether we're using the interrupt
// off by default!
boolean usingInterrupt = false;
void useInterrupt(boolean); // Func prototype keeps Arduino 0023 happy
float conv_coords (float formattedLatLon)
  float decDegrees =  (float) floor(formattedLatLon / 100);
  float decMinutesOrig = (((formattedLatLon / 100) - decDegrees) * 100);
  float decMinutes = floor(decMinutesOrig);
  float decFractMinutes = (decMinutesOrig - decMinutes) * 60;
  return decDegrees + (decMinutes / 60) + (decFractMinutes / 3600);
void setup()
  // connect at 115200 so we can read the GPS fast enough and echo without dropping chars
  // also spit it out
  Serial.begin(115200);
  Serial.println("Adafruit GPS library basic test!");
  // 9600 NMEA is the default baud rate for Adafruit MTK GPS's- some use 4800
  GPS.begin(9600);
  // uncomment this line to turn on RMC (recommended minimum) and GGA (fix data) including altitude
  GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
  // uncomment this line to turn on only the "minimum recommended" data
  //GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCONLY);
  // For parsing data, we don't suggest using anything but either RMC only or RMC+GGA since
  // the parser doesn't care about other sentences at this time
  // Set the update rate
  GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ);   // 1 Hz update rate
  // For the parsing code to work nicely and have time to sort thru the data, and
  // print it out we don't suggest using anything higher than 1 Hz
  // Request updates on antenna status, comment out to keep quiet
  GPS.sendCommand(PGCMD_ANTENNA);
  // the nice thing about this code is you can have a timer0 interrupt go off
  // every 1 millisecond, and read data from the GPS for you. that makes the
  // loop code a heck of a lot easier!
  useInterrupt(true);
  delay(1000);
  // Ask for firmware version
  mySerial.println(PMTK_Q_RELEASE);
// Interrupt is called once a millisecond, looks for any new GPS data, and stores it
SIGNAL(TIMER0_COMPA_vect) {
  char c = GPS.read();
  // if you want to debug, this is a good time to do it!
#ifdef UDR0
  if (GPSECHO)
    if (c) UDR0 = c;
    // writing direct to UDR0 is much much faster than Serial.print
    // but only one character can be written at a time.
#endif
void useInterrupt(boolean v) {
  if (v) {
    // Timer0 is already used for millis() - we'll just interrupt somewhere
    // in the middle and call the "Compare A" function above
    OCR0A = 0xAF;
    TIMSK0 |= _BV(OCIE0A);
    usingInterrupt = true;
  } else {
    // do not call the interrupt function COMPA anymore
    TIMSK0 &= ~_BV(OCIE0A);
uint32_t timer = millis();
void loop()                     // run over and over again
  // in case you are not using the interrupt above, you'll
  // need to 'hand query' the GPS, not suggested :(
  if (! usingInterrupt) {
    // read data from the GPS in the 'main loop'
    if (GPSECHO)
      if (c) Serial.print(c);
  // if a sentence is received, we can check the checksum, parse it...
  if (GPS.newNMEAreceived()) {
    // a tricky thing here is if we print the NMEA sentence, or data
    // we end up not listening and catching other sentences!
    // so be very wary if using OUTPUT_ALLDATA and trytng to print out data
    //Serial.println(GPS.lastNMEA());   // this also sets the newNMEAreceived() flag to false
    if (!GPS.parse(GPS.lastNMEA()))   // this also sets the newNMEAreceived() flag to false
      return;  // we can fail to parse a sentence in which case we should just wait for another
  // if millis() or timer wraps around, we'll just reset it
  if (timer > millis())  timer = millis();
  // approximately every 2 seconds or so, print out the current stats
  if (millis() - timer > 2000) {
    timer = millis(); // reset the timer
    Serial.print("\nTime: ");
    Serial.print(GPS.hour, DEC); Serial.print(':');
    Serial.print(GPS.minute, DEC); Serial.print(':');
    Serial.print(GPS.seconds, DEC); Serial.print('.');
    Serial.println(GPS.milliseconds);
    Serial.print("Date: ");
    Serial.print(GPS.day, DEC); Serial.print('/');
    Serial.print(GPS.month, DEC); Serial.print("/20");
    Serial.println(GPS.year, DEC);
    Serial.print("Fix: "); Serial.print((int)GPS.fix);
    Serial.print(" quality: "); Serial.println((int)GPS.fixquality);
    if (GPS.fix) {
      Serial.print("Location: ");
      Serial.print(conv_coords(GPS.latitude)); Serial.print(GPS.lat);
      Serial.print(", ");
      Serial.print(conv_coords(GPS.longitude)); Serial.println(GPS.lon);
      Serial.print("Speed (knots): "); Serial.println(GPS.speed);
      Serial.print("Angle: "); Serial.println(GPS.angle);
      Serial.print("Altitude: "); Serial.println(GPS.altitude);
      Serial.print("Satellites: "); Serial.println((int)GPS.satellites);
Joshua_J0
Post by Joshua_J0 »
Ah, that worked for me as well. Thanks so much! I had
Serial.print(conv_coords(GPS.latitude, 4)); Serial.print(GPS.lat);
in the old code so maybe the ,4 was tripping it up…idk. But thanks for your help!
Phoenix92
Post by Phoenix92 »
Hi all,
This is my first post so be gentle!
I am currently trying to produce a tracking device for my motorcycle i am using a:
-Arduino Uno
-Adafruit Breakout GPS
-Arduino GSM (the telefonica one not the common sm900!)
I have been scouring the web now for a good few weeks to try n find a solution to being able to send (via gsm) the gps data taken from the breakout gps! I hope someone out there can help me!
I have changed my code to use the altsoftserial library for the gps but i dont seem to be able to make it work!
Bottom line is i am just trying to combine the parsing example code with the SendSMS gsm example code!
Help!
adafruit_support_mike
Post the code you have now and we'll take a look.
parmares
Post by parmares »
Hi all,
I try to use GPS with GSM arduino and Mega board so I changed the libraries to AltSoftSerial and Adafruit_GPS_Alt . Now I couldn't get result by using parsing example.
I just ran the parsing example without GSM shield and I got this:
Time: 0:0:0.0
Date: 0/0/200
Fix: 0 quality: 0
But when I use UNO board it works perfect.
any suggestion please?
The pinouts on a Mega are very different than on an UNO. You can't use the same pins for software serial. See the board compatibility guide for a workaround:
https://learn.adafruit.com/adafruit-shi ... l-variants
parmares
Post by parmares »
Thanks for your reply, I got it .
I connect pin 8 to 48 and pin 9 to 46 and now I got the result.
Thanks again
Return to “Arduino”
