Linking Four SHift Register
Re: Linking Four SHift Register
by adafruit_support_mike on Sun Apr 28, 2013 5:54 pm
bob500000 wrote:Still not too sure what you meant by checkbuttons.
That was just a name I made up while I was writing the example code. When I write snippets I tend to skip over details by calling a function with a name that describes what should happen at that point. Use your check_switches() function there.
Does the system do what you want with that code?
by bob500000 on Sun Apr 28, 2013 6:18 pm
Hi mike,
Thanks for that, was thinking that but, the second button doesn't work it is either live or not on the last shift registers in theory, by pressing the switch it should swap to shift registers 3 and 4, am I correct?
So I currently have to following edited of course, I need to the LED's to stop once a a cycle has finished, say lighting all 16 bits, which then calls the results function.
When the user presses the second button then the method test 2 executes and runs the exact same code as test 1 but on shift register 3 and 4.
Currently I can't get any LED's to light up, I can confirm that the wiring is correct.
Cheers.
#include <Button.h>
int latchPin = 5;
int clockPin = 6;
int dataPin = 4;
int latchPin2 = 0;
int clockPin2 = 1;
int dataPin2 = 2;
int outputEnablePin = 3;
int outputEnablePin2 = 14;
int ledPin = 10;
//Button trigger = Button(2,LOW);
int sr1Colour = 0;  // Set for ShiftReg1 as 0 = off, 1 = green, 2 = red
int sr2Colour = 0;
int ledState = 0;
int ledState2 = 0;
const int ON = HIGH;
const int OFF = LOW;
int bright = 0;    // how bright the LED is
int fadeAmount = 5;    // how many points to fade the LED by
byte leds = 0;
byte button[] = {7, 8};
byte switch_value = 0;
boolean btnOn = false;
int count = 0;
#define NUMBUTTONS sizeof(button)
byte pressed[NUMBUTTONS], justpressed[NUMBUTTONS], justreleased[NUMBUTTONS];
  //setBrightness(0);
  pinMode(latchPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(outputEnablePin, OUTPUT);
  pinMode(outputEnablePin2, OUTPUT);
 pinMode(latchPin2, OUTPUT);
  pinMode(dataPin2, OUTPUT);
  pinMode(clockPin2, OUTPUT);
  //pinMode(2,INPUT); //Trigger switch sits on pin 2
  Serial.begin(9600);
  Serial.println("Welcome");
  byte i;
   for (i=0; i< NUMBUTTONS; i++) {
    pinMode(button[i], INPUT);
    digitalWrite(button[i], HIGH);
    //Timer2 Overflow Interrupt Enable
  TIMSK2 |= 1<<TOIE2;
//byte pressCount1 = 0;
SIGNAL(TIMER2_OVF_vect) {
  check_switches();
void check_switches()
  static byte previousstate[NUMBUTTONS];
  static byte currentstate[NUMBUTTONS];
  byte index;
  for (index = 0; index < NUMBUTTONS; index++) {
    currentstate[index] = digitalRead(button[index]);   // read the button
    Serial.print(index, DEC);
    Serial.print(": cstate=");
    Serial.print(currentstate[index], DEC);
    Serial.print(", pstate=");
    Serial.print(previousstate[index], DEC);
    Serial.print(", press=");
    if (currentstate[index] == previousstate[index]) {
      if ((pressed[index] == LOW) && (currentstate[index] == LOW)) {
          // just pressed
          justpressed[index] = 1;
          count = count+1;
          //switch_value = switch_value + 1;
      else if ((pressed[index] == HIGH) && (currentstate[index] == HIGH)) {
          // just released
          justreleased[index] = 1;
      pressed[index] = !currentstate[index];  // remember, digital HIGH means NOT pressed
    //Serial.println(pressed[index], DEC);
    previousstate[index] = currentstate[index];   // keep a running tally of the buttons
 //This is Button 1 Set Press
 updateLEDs(ledState == -5);
  idle();
  if(justpressed[0])
    updateLEDs2(ledState == -5);
    Serial.print("Button 1 pressed");
    btnOn = true;
    idleoff();
  int delayTime = 2000; //the number of milliseconds to delay between LED updates
  for(int i = 0; i < 16; i++){
  updateLEDs(i);
  delay(delayTime);
// //This is Button 2 Set Press
if(justpressed[1])
    //updateLEDs2(ledState == -5);
    Serial.print("Button 2 pressed");
    btnOn = true;
    idleoff();
    Serial.print("For");
  updateLEDs2(i);
  delay(delayTime);
   Result();
//This the idle setup
void idle()
  // set the brightness of pin 9:
  analogWrite(10, bright);
  // change the brightness for next time through the loop:
  bright = bright + fadeAmount;
  // reverse the direction of the fading at the ends of the fade:
  if (bright == 0 || bright == 255) {
    fadeAmount = -fadeAmount ;
  // wait for 30 milliseconds to see the dimming effect
  delay(100);
//This the idle off switch
void idleoff()
  analogWrite(10,0);
void Result()
  analogWrite(11, bright);
  delay(70);
//// // Test1
void updateLEDs(uint16_t value){
    digitalWrite(latchPin, LOW);                           //Pulls the chips latch low
    shiftOut(dataPin, clockPin, MSBFIRST, value >> 8);    //Shifts the upper 8 bits of 'value'
    shiftOut(dataPin, clockPin, MSBFIRST, value);         //Shifts the lower 8 bits of 'value'
    digitalWrite(latchPin, HIGH);                          //Pulls the latch high displaying the data
void updateLEDsLong(uint16_t value){
    for(int i = 16 ; i >= 0 ; i++) {        //  start at the high end and move to the low end
        if((value >> i) & 1) {              //  shift the i-th bit to the 1s position
            digitalWrite(dataPin, HIGH);
        } else {
            digitalWrite(dataPin, LOW);
        digitalWrite(clockPin, HIGH);
        delay(1);
        digitalWrite(clockPin, LOW);
void changeLED(int led, int state) {
    uint16_t bit = 1 << led;                //  all zeros except for a 1 at position 'led'
    ledState = ledState | bit;            //  set the bit high by default
    if(state == OFF) {
        ledState = ledState ^ bit;        //  set the bit low with an exclusive-OR
    updateLEDs(ledState);
    setBrightness (255);
//// // Test2
void updateLEDs2(int value){
  digitalWrite(latchPin2, LOW);     //Pulls the chips latch low
  shiftOut(dataPin2, clockPin2, MSBFIRST, value); //Shifts out the 8 bits to the shift register
  digitalWrite(latchPin2, HIGH);   //Pulls the latch high displaying the data
 * updateLEDsLong() - sends the LED states set in ledStates to the 74HC595
 * sequence. Same as updateLEDs except the shifting out is done in software
 * so you can see what is happening.
void updateLEDs2(uint16_t value){
    shiftOut(dataPin2, clockPin2, MSBFIRST, value >> 8);    //Shifts the upper 8 bits of 'value'
    shiftOut(dataPin2, clockPin2, MSBFIRST, value);         //Shifts the lower 8 bits of 'value'
void updateLEDsLong2(uint16_t value){
            digitalWrite(dataPin2, HIGH);
        } else {
            digitalWrite(dataPin2, LOW);
        digitalWrite(clockPin2, HIGH);
        delay(1);
        digitalWrite(clockPin2, LOW);
void changeLED2(int led, int state) {
    ledState2 = ledState2 | bit;            //  set the bit high by default
    if(state == OFF) {
        ledState2 = ledState2 ^ bit;        //  set the bit low with an exclusive-OR
    updateLEDs2(ledState2);
    setBrightness2 (255);
 //This is setBrightness
void setBrightness(byte brightness) // 0 to 255
  analogWrite(outputEnablePin, 255-brightness);
void setBrightness2(byte brightness) // 0 to 255
  analogWrite(outputEnablePin2, 255-brightness);
bob500000
by adafruit_support_mike on Sun Apr 28, 2013 11:46 pm
You have two versions of the updateLEDs2() function in the code:
//// // Test2
That's probably causing some confusion about which one to execute. I'm surprised it compiles without a warning, but just confirmed that it does.
It doesn't look like you use any of the functions:
- UpdateLEDsLong()
- UpdateLEDsLong2()
- changeLED()
- changeLED2()
so you may as well remove those from the file too.
This loop:
  updateLEDs2(i);
  delay(delayTime);
will only light the last four LEDs, even when everything works as it should. The bit patterns for the integers 0-15 are [0000, 0001, 0010, 0011, 0100, 0101, 0110, 0111, 1000, 1001, 1010, 1011, 1100, 1101, 1110, 1111]
To light each of the 16 LEDs in turn, try this:
  updateLEDs2( 0x8000 >> i );
I don't see any code that would swap the values that go to shift registers 3 and 4.
by bob500000 on Mon Apr 29, 2013 3:21 am
Hi MIke,
Thanks for that, must have missed that part out of the trimming re: updateLEDs2 method.
Well the shift registers are independant of the first set so surely but duplicating the same structure will work, just amending if for example:
int latchPin = 5;
int clockPin = 6;
int dataPin = 4;
int latchPin2 = 0;
int clockPin2 = 1;
int dataPin2 = 2;
Cheers
bob500000
by adafruit_support_mike on Mon Apr 29, 2013 2:04 pm
The code should work the same way for both pairs of shift registers, yes. Let's strip away some of the complexity and check that assumption though:
int latchPin = 5;
int clockPin = 6;
int dataPin = 4;
int latchPin2 = 0;
int clockPin2 = 1;
int dataPin2 = 2;
    Serial.begin(9600);
    byte i;
    int wait = 250;
    Serial.println("Testing the first pair of shift registers:");
    for (i=15 ; i >= 0 ; i--) {
        Serial.print("  LED #");
        Serial.println( i+1 );
        updateLEDs( 1 << i );
        delay( wait );
    Serial.println("Testing the second pair of shift registers:");
        updateLEDs2( 1 << i );
        delay( wait );
by bob500000 on Mon Apr 29, 2013 4:51 pm
Hi mike,
So in terms of the buttons, how would you get them to give the desired results?
Would you call separate methods as I have or would you just put the conditions into the if statement?
Cheers
bob500000
by bob500000 on Tue Apr 30, 2013 6:13 pm
Hi mike thanks for all your assistance,
It's been submitted now but a picture of it wil follow tomorrow, if you require anything else from me let me know.
Cheers bob.
bob500000
by bob500000 on Wed May 01, 2013 10:13 am
As requested here is a picture of the completed project.
bob500000
by adafruit_support_bill on Thu May 02, 2013 8:09 am
Thanks for the photo. :) Was this for a class project?
by bob500000 on Thu May 02, 2013 8:11 am
Final year dissertation project bill
Lots of planning asking questions to get it right! In the end!
bob500000
