Good Morning,
I'm dealing with some problems to have my new camera working with Netduino Plus. I've checked everything on the camera tutorial and made the right connections too. I know that the tutorial is for Arduino, but... Could you give some support or hint to solve my issue? The CommTool is not working also, giving Commands Timeout...
I'll be waiting for your feedback.
Thanks in advance.
VC0706 Weatherproof TTL Camera and Netduino Plus
Re: VC0706 Weatherproof TTL Camera and Netduino Plus
On the Arduino Uno, digital pins 0 and 1 are also connected to the USB/Serial converter. This allows us to use the pass-through trick to connect the camera to the computer.
I don't know the Netduino serial works in the same way. If not, the pass-through connection for the camera will not work and you would have to use an FTDI cable or FTDI Friend to make the connection.
You might ask this question over at the Netduino forum. http://forums.netduino.com/
