Have old 0012 code that isn't compiling in 1.5.2
by GreyFox5 on Thu Apr 18, 2013 9:30 pm
I had someone set this code up for me and 12 Nixie Tubes. But I cannot get this to complie in 1.5.2 could someone help?
Error info here:
In file included from OgiLumen_Chasing_3s.pde:13:
C:\Users\Game\Downloads\Arduino\arduino-1.5.2\hardware\arduino\avr\cores\arduino/Nixie.h:57: error: 'byte' has not been declared
In file included from OgiLumen_Chasing_3s.pde:37:
C:\Users\Game\Downloads\Arduino\arduino-1.5.2\hardware\arduino\avr\cores\arduino/Arduino.h:113: error: expected ',' or '...' before numeric constant
C:\Users\Game\Downloads\Arduino\arduino-1.5.2\hardware\arduino\avr\cores\arduino/Arduino.h:114: error: expected ',' or '...' before numeric constant
Code here:
          change this file name to wigwagnixie.pde
  nixie_write_trim - sample code using the Nixie library
 for controlling the Ogi Lumen nixie tube driver.
 Created by Lionel Haims, July 25, 2008.
 Released into the public domain.
  Design of output by James Sanders 4/17/09
// include the library
#include <Nixie.h>
// note the digital pins of the arduino that are connected to the nixie driver
#define dataPin 2  // data line or SER
#define clockPin 3 // clock pin or SCK
#define latchPin 4 // latch pin or RCK
// note the number of digits (nixie tubes) you have (buy more, you need more)
#define numDigits 16
// just some defines to simplify the examples
#define shortDelay 2   // higher causes a slight flash when updating
#define longDelay 800
#define wagDelay 170        // lower causes faster wigwag
#define ladelay 50           // ladder routine delay
#define fallDelay 40        //  delay between digit falls.
#define waveDelay 50        // wave delay
// Create the Nixie object
// pass in the pin numbers in the correct order
Nixie nixie(dataPin, clockPin, latchPin);
void setup()
  // Clear the display if you wish
  nixie.clear(numDigits);
void loop()
  int tube = 1;
  int i = 1;
  int count = 0;
  //int rnd = random(0,9);
  // just some local variables to help the example
  //int highestNum = pow(10,numDigits)-1;
  // 3894057261 is the height order
  //rnd = random(0,9);
  //randomSeed(rnd);
  delay(longDelay);
  // try for wave .
  nixie.writeNumTrim( 3,1);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  nixie.writeNumTrim( 8,1);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  nixie.writeNumTrim( 9,1);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  nixie.writeNumTrim( 4,1);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  nixie.writeNumTrim( 0,1);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  nixie.writeNumTrim( 5,1);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  nixie.writeNumTrim( 7,1);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  nixie.writeNumTrim( 2,1);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  nixie.writeNumTrim( 6,1);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  nixie.writeNumTrim( 1,1);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  delay(waveDelay);
  //nixie.clear(1);
  delay(shortDelay);
  // 3's chasing 6's ==================================
  for (tube=1; tube <= numDigits; tube = tube + 1)
    // randomSeed(rnd);
    nixie.writeNumTrim( 3,tube);
    delay(wagDelay);
    delay(shortDelay);
  for (tube=12; tube >= 1; tube--)
    nixie.writeNumTrim( 6,tube);
    delay(wagDelay+40);
    delay(shortDelay);
  // fast sweep   a 3 ====================================
    // randomSeed(rnd);
    delay(100);
    delay(shortDelay);
//dive down to 6
i = numDigits;
   // nixie.writeNumTrim( 3,i);
    //delay(fallDelay);
    //nixie.clear(numDigits);
    //delay(shortDelay);
    nixie.writeNumTrim( 8,i);
    delay(fallDelay);
    delay(shortDelay);
    nixie.writeNumTrim( 9,i);
    delay(fallDelay);
    delay(shortDelay);
    nixie.writeNumTrim( 4,i);
    delay(fallDelay);
    delay(shortDelay);
    nixie.writeNumTrim( 0,i);
    delay(fallDelay);
    delay(shortDelay);
    nixie.writeNumTrim( 5,i);
    delay(fallDelay);
    delay(shortDelay);
    nixie.writeNumTrim( 7,i);
    delay(fallDelay);
    delay(shortDelay);
    nixie.writeNumTrim( 2,i);
    delay(fallDelay);
    delay(shortDelay);
    nixie.writeNumTrim( 6,i);
    delay(fallDelay);
    delay(shortDelay);
    nixie.writeNumTrim( 1,i);
    delay(fallDelay);
    delay(shortDelay);
  for (tube=numDigits; tube >= 1; tube--)
    delay(100);
    delay(shortDelay);
// bring level up to 3.
i = 1;
   // nixie.writeNumTrim( 1,i);
   // delay(fallDelay);
   // nixie.clear(numDigits);
   // delay(shortDelay);
   // nixie.writeNumTrim( 6,i);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    // randomSeed(rnd);
    delay(100);
    delay(shortDelay);
//dive down to 6
i = numDigits;
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(100);
    delay(shortDelay);
i = 1;
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
  // faster yet sweep multi  pass=====================================================
    // randomSeed(rnd);
    delay(30);
    delay(shortDelay);
    delay(30);
    delay(shortDelay);
    delay(30);
    delay(shortDelay);
    delay(30);
    delay(shortDelay);
    delay(60);
    delay(shortDelay);
    delay(60);
    delay(shortDelay);
    delay(100);
    delay(shortDelay);
    delay(100);
    delay(shortDelay);
    delay(180);
    delay(shortDelay);
    delay(200);
    delay(shortDelay);
  delay(longDelay);
  // ladder sweep ===========================================================
  for (tube=1; tube <= 2; tube = tube + 1)
    // randomSeed(rnd);
    delay(ladelay + (ladelay*.4));  // slow down the short sweeps a little
    delay(shortDelay);
  for (tube=2; tube >= 1; tube--)
    delay(shortDelay);
  // ladder to 3
  for (tube=1; tube <= 3; tube = tube + 1)
    // randomSeed(rnd);
    delay(shortDelay);
  for (tube=3; tube >= 1; tube--)
    delay(shortDelay);
  // ladder to 4
  for (tube=1; tube <= 4; tube = tube + 1)
    // randomSeed(rnd);
    delay(ladelay);
    delay(shortDelay);
  for (tube=4; tube >= 1; tube--)
    delay(ladelay);
    delay(shortDelay);
  // ladder to 5
  for (tube=1; tube <= 5; tube = tube + 1)
    // randomSeed(rnd);
    delay(ladelay);
    delay(shortDelay);
  for (tube=5; tube >= 1; tube--)
    delay(ladelay);
    delay(shortDelay);
  // ladder to 6
  for (tube=1; tube <= 6; tube = tube + 1)
    // randomSeed(rnd);
    delay(ladelay);
    delay(shortDelay);
  for (tube=6; tube >= 1; tube--)
    delay(ladelay);
    delay(shortDelay);
  // ladder to 8
  for (tube=1; tube <= 8; tube = tube + 1)
    delay(ladelay);
    delay(shortDelay);
  for (tube=8; tube >= 1; tube--)
    delay(ladelay);
    delay(shortDelay);
  // ladder to 10
  for (tube=1; tube <= 10; tube = tube + 1)
    // randomSeed(rnd);
    delay(ladelay);
    delay(shortDelay);
  for (tube=10; tube >= 1; tube--)
    delay(ladelay);
    delay(shortDelay);
  // ladder to 11
  for (tube=1; tube <= 11; tube = tube + 1)
    delay(ladelay);
    delay(shortDelay);
  for (tube=11; tube >= 1; tube--)
    delay(ladelay);
    delay(shortDelay);
  // ladder to 13
  for (tube=1; tube <= 13; tube = tube + 1)
    // randomSeed(rnd);
    delay(ladelay);
    delay(shortDelay);
  for (tube=13; tube >= 1; tube--)
    delay(ladelay);
    delay(shortDelay);
  // ladder to 14
  for (tube=1; tube <= 14; tube = tube + 1)
    // randomSeed(rnd);
    delay(ladelay);
    delay(shortDelay);
  for (tube=14; tube >= 1; tube--)
    delay(ladelay);
    delay(shortDelay);
  // ladder to 16
  for (tube=1; tube <= 16; tube = tube + 1)
    // randomSeed(rnd);
    delay(ladelay);
    delay(shortDelay);
  for (tube=16; tube >= 1; tube--)
    delay(ladelay);
    delay(shortDelay);
  // ladder to 14
    // randomSeed(rnd);
    delay(ladelay);
    delay(shortDelay);
    delay(ladelay);
    delay(shortDelay);
  // ladder to 12
  for (tube=1; tube <= 12; tube = tube + 1)
    // randomSeed(rnd);
    delay(ladelay);
    delay(shortDelay);
    delay(ladelay);
    delay(shortDelay);
  // ladder to 10
    delay(ladelay);
    delay(shortDelay);
    delay(ladelay);
    delay(shortDelay);
  // ladder to 8
    // randomSeed(rnd);
    delay(ladelay);
    delay(shortDelay);
    delay(ladelay);
    delay(shortDelay);
  // ladder to 7
  for (tube=1; tube <= 7; tube = tube + 1)
    delay(ladelay);
    delay(shortDelay);
  for (tube=7; tube >= 1; tube--)
    delay(ladelay);
    delay(shortDelay);
  // ladder to 6
    // randomSeed(rnd);
    delay(ladelay);
    delay(shortDelay);
    delay(ladelay);
    delay(shortDelay);
  // ladder to 5
    // randomSeed(rnd);
    delay(ladelay);
    delay(shortDelay);
    delay(ladelay);
    delay(shortDelay);
  // ladder to 4
    // randomSeed(rnd);
    delay(ladelay);
    delay(shortDelay);
    delay(ladelay);
    delay(shortDelay);
  // ladder to 3
    // randomSeed(rnd);
    delay(shortDelay);
    delay(shortDelay);
  // ladder to 2
    delay(shortDelay);
    delay(shortDelay);
  delay(longDelay);
  // count fast to 3333 =========================================
  for(i=0; i <= 7777; i++)
    // Write the number
    nixie.writeNumTrim( i, 4);
    delay(shortDelay/3);
delay(longDelay);
  // fall each digit in turn
  for(i=1; i <=numDigits; i++)
    delay(wagDelay);
    delay(shortDelay);
    nixie.writeNumTrim( 8,2);
    delay(wagDelay);
    delay(shortDelay);
    nixie.writeNumTrim( 8,3);
    delay(wagDelay);
    delay(shortDelay);
    nixie.writeNumTrim( 9,4);
    delay(wagDelay);
    delay(shortDelay);
    nixie.writeNumTrim( 4,5);
    delay(wagDelay);
    delay(shortDelay);
    nixie.writeNumTrim( 0,6);
    delay(wagDelay);
    delay(shortDelay);
    nixie.writeNumTrim( 5,7);
    delay(wagDelay);
    delay(shortDelay);
   nixie.writeNumTrim( 7,8);
    delay(wagDelay);
    delay(shortDelay);
    nixie.writeNumTrim( 7,9);
    delay(wagDelay);
    delay(shortDelay);
    nixie.writeNumTrim( 2,10);
    delay(wagDelay);
    delay(shortDelay);
    nixie.writeNumTrim( 6,11);
    delay(wagDelay);
    delay(shortDelay);
    nixie.writeNumTrim( 1,12);
    delay(wagDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
//for(i=1; i <=numDigits; i++)
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
    delay(fallDelay);
    delay(shortDelay);
  // wait for the next example
  delay(longDelay);
  delay(longDelay);
  delay(longDelay);
Last edited by adafruit_support_bill on Fri Apr 19, 2013 3:41 pm, edited 1 time in total.
Reason: Please use the 'code' button when submitting code
GreyFox5
Re: Have old 0012 code that isn't compiling in 1.5.2
by franklin97355 on Fri Apr 19, 2013 1:06 pm
Does this compile under 0012? Also if you include code place it between code tags so it is more readable and for large amounts of code attach the file rather that posting the code inline.
franklin97355
by adafruit_support_bill on Fri Apr 19, 2013 3:47 pm
Is that where you installed the nixie library? See this guide for how (and where) to install.
http://learn.adafruit.com/adafruit-all- ... -a-library
by ogilumen on Sat May 25, 2013 2:01 am
Ahoy,
The fix is in. Sample code now plays nice with Arduino 1.0.4
See http://www.ogilumen.com/pub/fileroom/001/drivermux.zip
ogilumen
ogilumen
