Good day,
Have an issue to be cleared. If i gonna use an Arduino UNO to controll following pixels: http://learn.adafruit.com/adafruit-ardu ... theory-pwm without the WS2801 LED driver chip, i just need to provide the appropriate programming code?
Just to be clear.. Looking forward,
Arduino UNO + 36mm RBG Pixel
- Franklin97355
Re: Arduino UNO + 36mm RBG Pixel
If you plan to drive rgb leds directly that will work but I believe the Adafruit 36mm pixels have a controller built in.
Yes it is. But in my local shop followings LED are without controller.franklin97355 wrote:If you plan to drive rgb leds directly that will work but I believe the Adafruit 36mm pixels have a controller built in.
- Franklin97355
Then are they really 36mm RGB pixels?But in my local shop followings LED are without controller
It was similar to 36mm RGB LED. But just i while ago have ordered from adafruit 36mm RGB pixels string of 20psc.franklin97355 wrote:Then are they really 36mm RGB pixels?But in my local shop followings LED are without controller
And i was forced to change RGB LED control method to control via voice with Arduino UNO.
I have follwoing Voice recognition device compatitable with Arduino: http://www.ebay.com/itm/Voice-Recogniti ... 20bd30714f
But i`am not sure how it could be proceed.....
- Franklin97355
There are instructions and demo code on that page.
