Fingerprint sensor
Fingerprint sensor
Hi everybody, i have a problem with a fingerprint sensor.I buy an fingerprint sensor on adafruit.com when i connect my fingerprint sensor on my arduino it works and when i connect my fingerprint sensor with the led it work as in the video tuto but when i connect my screen lcd on this as in the video tuto nothing appears. I need help pleas Thank's
- adafruit_support_rick
Re: Fingerprint sensor
What sketch are you using when you connect the LCD? I believe that was something that Becky wrote for the video - I don't think we have any example sketches that talk to the LCD.
i used the fingerprint sketch What should I add to my program, I tried to add blibiothéque the lcd but nothing appears you can write what I should add in fingerprint sketch
Is this the display you are using? http://learn.adafruit.com/rgb-lcd-shield
The tutorial explains how to install the library and has some example code for writing to the display.
Yes it is about the same except that I use a screen with SEVERAL output
Just use as many lcd.print(), lcd.println(), and lcd.setCursor() statements as you need.
Maybe have a look at our Arduino Lesson #5. The lesson talks about the Serial Monitor, but the operations are the same with lcd.
So, wherever you see "Serial.print", substitute "lcd.print".
You can also look at the Arduino reference pages on Serial.print and Serial.println.
Again, substitute "lcd" for "Serial".
Hi @adafruit_support_rick thank's for you help you provide me i'm an amateur in arduino Could you comment on me every line Adafruit_fingerprint program please because I do not understand all the program lines Thank's
This is the program AdaFruit_fingerprint
#include <Adafruit_Fingerprint.h>
#if ARDUINO >= 100
#include <SoftwareSerial.h>
#else
#include <NewSoftSerial.h>
#endif
int getFingerprintIDez();
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino (WHITE wire)
#if ARDUINO >= 100
SoftwareSerial mySerial(2, 3);
#else
NewSoftSerial mySerial(2, 3);
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
void setup()
Serial.begin(9600);
Serial.println("fingertest");
// set the data rate for the sensor serial port
finger.begin(57600);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
} else {
Serial.println("Did not find fingerprint sensor :(");
while (1);
Serial.println("Waiting for valid finger...");
void loop() // run over and over again
uint8_t getFingerprintID() {
uint8_t p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
break;
case FINGERPRINT_NOFINGER:
Serial.println("No finger detected");
return p;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
return p;
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
return p;
default:
Serial.println("Unknown error");
return p;
// OK success!
p = finger.image2Tz();
switch (p) {
Serial.println("Image converted");
break;
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
// OK converted!
p = finger.fingerFastSearch();
if (p == FINGERPRINT_OK) {
Serial.println("Found a print match!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_NOTFOUND) {
Serial.println("Did not find a match");
return p;
} else {
return p;
// found a match!
Serial.print("Found ID #"); Serial.print(finger.fingerID);
Serial.print(" with confidence of "); Serial.println(finger.confidence);
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
if (p != FINGERPRINT_OK) return -1;
// found a match!
return finger.fingerID;
First question: Does it work?SofianeSIN wrote:Hi @adafruit_support_rick thank's for you help you provide me i'm an amateur in arduino Could you comment on me every line Adafruit_fingerprint program please because I do not understand all the program lines Thank's
yes it works you can comment the fingerprint program please
i have same problem that posted above i'm using liquidcrystal.h library for lcd . when i connect lcd fp with arduino then fingertest only show's at the lcd and after some but not showing that Found fingerprint sensor! etc.
i don't know wiring for lcd in serial mode.
Please don't triple-post. I've answered your post on this subject here:umer wrote:i have same problem that posted above
http://forums.adafruit.com/viewtopic.ph ... 40#p287412
