32x16 and 32x32 RGB LED Matrix, Tri-Color Displays with Arduino UNO
by wsg on Sat May 04, 2013 7:58 am
Is there a tutorial on chaining and a library code for using these Tri-Color LED Matrix Displays with an Arduino UNO or with the Arduino DUE?
What are the advantages for using a FPGA development board to do this instead of the Arduino UNO?
There is a tutorial using the DE0-Nano FPGA Board with
Adafruit 32x16 RGB LED Matrix Displays but there is not much information on the wiriing or code and there is no chain of multiple displays.
http://learn.adafruit.com/fpga-rgb-matrix
Controlling the Adafruit 32x16 RGB LED Matrix with a DE0-Nano FPGA Board
http://www.adafruit.com/products/420
http://www.adafruit.com/products/607
This is a tutorial for only one LED Matrix Tri-Color Display
http://learn.adafruit.com/32x16-32x32-rgb-led-matrix/
This is a tutorial chaining multiple 16x24 LED Matrix Display but for Single Color Displays
http://ladyada.net/products/16x24LEDmatrix/
16x24 LED Matrix Easy to use, chainable displays, single color
Thanks much. :o
wsg
Re: 32x16 and 32x32 RGB LED Matrix, Tri-Color Displays with Arduino UNO
by pburgess on Sat May 04, 2013 10:12 am
We don't have any Arduino-based examples for chaining these displays, reason being...well, you know the phrase "squeezing blood from a stone"? The limited resources of the Arduino make this difficult and of questionable utility, so we instead decided to focus on a single display with a passable color range and decent refresh rate.
Ray's Logic has been doing some work with chaining these displays using the Propeller platform:
http://www.rayslogic.com/propeller/prog ... uitRGB.htm
The Arduino Due could very likely handle this, but the necessary code has not yet been written and we have no ETA.
pburgess
