Need some feedback
Need some feedback
by patrikk on Sat May 04, 2013 4:00 pm
Hi everyone,
I've been working on a menu lib to be able to to traverse through a menu on the LCD.
the structure is similar to the tree structure you have in explorer etc.
My problem is that I cant get it to work perfectly. in the code I've posted here I can step through the menu up and down( submenu) and into menu "item2" but I can't do that with the first item (item1) instead it jumps to item3 and not to the "item1 submenu" what am I missing?
the second thing is that when I enter a submenu( submenu for item 2) I end up at the last submenuitem and not the first one. I can't figure out why it does that I would like it to go to the first subitem ( firstChild).
components:
Arduino Uno
adafruit 16x2 LCD negative with the I2C chip and buttons.
I appreciate all the help
library for the menu:
/*LcdMenu library*/
#ifndef   LcdMenu_h
#define LcdMenu_h
class MenuItem {
public:
   MenuItem(const char* itemName, char shortKey='\0' ) : name(itemName), shortkey(shortKey) {
      parent = prevSibling = nextSibling = firstChild = 0;
   inline const char* getName() const { return name; }
   inline const char getShortkey() const { return shortkey; }
   inline const bool hasShortkey() const { return (shortkey!='\0'); }
   inline void setBack(MenuItem *b) { parent = b; }
   inline MenuItem* getParent() const { return parent; }
   inline MenuItem* getPrevSibling() const { return prevSibling; }
   inline MenuItem* getNextSibling() const { return nextSibling; }
   inline MenuItem* getFirstChild() const { return firstChild; }
   MenuItem *moveBack() { return parent; }
   MenuItem *moveUp() {
      return prevSibling;
   MenuItem *moveDown() {
       return nextSibling;
   MenuItem *moveLeft() {
      return parent;
   MenuItem *moveRight() {
      return firstChild;
   //default menu
   MenuItem &setParent(MenuItem &mi) {
      mi.firstChild = this;
      parent = &mi;
      return mi;
   MenuItem &setPrevSibling(MenuItem &mi) {
      mi.nextSibling = this;
      prevSibling = &mi;
      return mi;
   MenuItem &setNextSibling(MenuItem &mi) {
      mi.prevSibling = this;
      nextSibling = &mi;
      return mi;
   MenuItem &setFirstChild(MenuItem &mi) {
      mi.parent = this;
      firstChild = &mi;
      return mi;
protected:
   const char* name;
   const char shortkey;
   MenuItem *parent;
   MenuItem *prevSibling;
   MenuItem *nextSibling;
   MenuItem *firstChild;
//no dependant inclusion of string or cstring
bool menuTestStrings(const char *a, const char *b) {
   while (*a) { if (*a != *b) { return false; } b++; a++; }
   return true;
bool operator==(const MenuItem &lhs, MenuItem &rhs) {
   return menuTestStrings(lhs.getName(),rhs.getName());
struct MenuChangeEvent {
   const MenuItem &from;
   const MenuItem &to;
struct MenuUseEvent {
   const MenuItem &item;
typedef void (*cb_change)(MenuChangeEvent);
typedef void (*cb_use)(MenuUseEvent);
class   LcdMenu {
public:
       LcdMenu(cb_use menuUse, cb_change menuChange = 0) : root("MenuRoot") {
      current = &root;
      cb_menuChange = menuChange;
      cb_menuUse = menuUse;
   MenuItem &getRoot() {
      return root;
   MenuItem &getCurrent() {
      return *current;
   void moveBack() {
      setCurrent(current->getParent());
   void moveUp() {
      setCurrent(current->moveUp());
   void moveDown() {
      setCurrent(current->moveDown());
   void moveLeft() {
      setCurrent(current->moveLeft());
   void moveRight() {
      setCurrent(current->moveRight());
   void use() {
      if (cb_menuUse) {
         MenuUseEvent mue = { *current };
         cb_menuUse(mue);
private:
   void setCurrent( MenuItem *next ) {
      if (next) {
         if (cb_menuChange) {
            MenuChangeEvent mce = { *current, *next };
            (*cb_menuChange)(mce);
         current = next;
   MenuItem root;
   MenuItem *current;
   cb_change cb_menuChange;
   cb_use cb_menuUse;
#endif
and then the project code:
#include <LcdMenu.h>    //LcdMenu library
#include <Wire.h>
#include <Adafruit_MCP23017.h>
#include <Adafruit_RGBLCDShield.h>
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
// These #defines make it easy to set the backlight color
#define RED 0x1
#define GREEN 0x2
#define YELLOW 0x3
#define BLUE 0x4
#define VIOLET 0x5
#define TEAL 0x6
#define WHITE 0x7
//Menu variables
LcdMenu menu = LcdMenu(menuUsed,menuChanged);
//initialize menuitems
    MenuItem menu1Item1 = MenuItem("Item1");
      MenuItem menuItem1SubItem1 = MenuItem("Item1SubItem1");
      MenuItem menuItem1SubItem2 = MenuItem("Item1SubItem2");
    MenuItem menu1Item2 = MenuItem("Item2");
      MenuItem menuItem2SubItem1 = MenuItem("Item2SubItem1");
      MenuItem menuItem2SubItem2 = MenuItem("Item2SubItem2");
      MenuItem menuItem2SubItem3 = MenuItem("Item2SubItem3");
    MenuItem menu1Item3 = MenuItem("Item3");
void setup()
  lcd.begin(16, 2);
  menu.getRoot().setNextSibling(menu1Item1);
  menu1Item1.setPrevSibling(menu1Item3);
  menu1Item1.setNextSibling(menu1Item2);
  menu1Item1.setFirstChild(menuItem1SubItem1);
    menuItem1SubItem1.setParent(menu1Item1);
    menuItem1SubItem1.setNextSibling(menuItem1SubItem2);
    menuItem1SubItem1.setPrevSibling(menuItem1SubItem2);
    menuItem1SubItem2.setPrevSibling(menuItem1SubItem1);
    menuItem1SubItem2.setNextSibling(menuItem1SubItem1);
    menuItem1SubItem2.setParent(menu1Item1);
  menu1Item2.setPrevSibling(menu1Item1);
  menu1Item2.setNextSibling(menu1Item3);
  menu1Item2.setFirstChild(menuItem2SubItem1);
    menuItem2SubItem1.setParent(menu1Item2);
    menuItem2SubItem1.setNextSibling(menuItem2SubItem2);
    menuItem2SubItem1.setPrevSibling(menuItem2SubItem3);
    menuItem2SubItem2.setPrevSibling(menuItem2SubItem1);
    menuItem2SubItem2.setNextSibling(menuItem2SubItem3);
    menuItem2SubItem2.setParent(menu1Item2);
    menuItem2SubItem3.setNextSibling(menuItem2SubItem1);
    menuItem2SubItem3.setParent(menu1Item2);
  menu1Item3.setParent(menu1Item1);
  menu1Item3.setPrevSibling(menu1Item2);
  menu1Item3.setNextSibling(menu1Item1);
    //menu1Item1.setPrevSibling(menu1Item3);
  //menu1Item3.setNextSibling(menu.getRoot());
  //menu.toRoot();
  lcd.setCursor(0,0);
  lcd.print("Main Menu");
}  // setup()...
void loop()
  readButtons();
} //loop()...
void menuChanged(MenuChangeEvent changed){
  MenuItem newMenuItem=changed.to; //get the destination menu
  lcd.setCursor(0,1); //set the start position for lcd printing to the second row
  if(newMenuItem.getName()==menu.getRoot()){
      lcd.print("Main Menu       ");
  }else if(newMenuItem.getName()=="Item1"){
      lcd.print("Item1           ");
  }else if(newMenuItem.getName()=="Item1SubItem1"){
      lcd.setCursor(0,0);
      lcd.print("--- Item1 ---");
      lcd.setCursor(0,1);
      lcd.print("Item1SubItem1");
  }else if(newMenuItem.getName()=="Item1SubItem2"){
      lcd.print("Item1SubItem2   ");
  }else if(newMenuItem.getName()=="Item2"){
    lcd.setCursor(0,0);
      lcd.print("   Main Menu    ");
      lcd.setCursor(0,1);
      lcd.print("Item2           ");
  }else if(newMenuItem.getName()=="Item2SubItem1"){
      lcd.setCursor(0,0);
      lcd.print("--- Item2 ---");
      lcd.setCursor(0,1);
      lcd.print("Item2SubItem1   ");
  }else if(newMenuItem.getName()=="Item2SubItem2"){
    lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      lcd.print("Item2SubItem2   ");
  }else if(newMenuItem.getName()=="Item2SubItem3"){
    lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      lcd.print("Item2SubItem3   ");
  }else if(newMenuItem.getName()=="Item3"){
      lcd.print("Item3           ");
void menuUsed(MenuUseEvent used){
  lcd.setCursor(0,0);
  lcd.print("You used        ");
  lcd.setCursor(0,1);
  lcd.print(used.item.getName());
  delay(1000);  //delay to allow message reading
  //menu.toRoot();  //back to Main
void  readButtons(){
  int reading;
uint8_t buttons = lcd.readButtons();
  if (buttons) {
    MenuItem currentMenu=menu.getCurrent();
    if (buttons & BUTTON_UP) {
      menu.moveUp();
      delay(500);
      lcd.setBacklight(RED);
    if (buttons & BUTTON_DOWN) {
      menu.moveDown();
      delay(500);
      lcd.setBacklight(YELLOW);
    if (buttons & BUTTON_LEFT) {
        menu.moveLeft();
        delay(500);
      lcd.setBacklight(GREEN);
    if (buttons & BUTTON_RIGHT) {
       menu.moveRight();
       delay(500);
       lcd.setBacklight(TEAL);
    if (buttons & BUTTON_SELECT) {
      if(!(currentMenu.moveRight())){  //if the current menu has a child and has been pressed enter then menu navigate to item below
        menu.use();
        delay(500);
      }else{  //otherwise, if menu has no child and has been pressed enter the current menu is used
        menu.moveRight();
        delay(500);
      lcd.setBacklight(VIOLET);
patrikk
Re: Need some feedback
by patrikk on Thu May 09, 2013 3:49 am
bump
patrikk
by adafruit_support_mike on Thu May 09, 2013 8:49 pm
The library looks generally okay, but you haven't posted the code that actually creates and navigates the menu. It's possible that you have some confusion between "up/down mean siblings" and "left/right mean parent/child".
by saltydog on Sun Aug 04, 2013 1:18 am
Hi Pat,
was wondering if you had this figured out yet with the menu system for the shield.
saltydog
