Pulse Brightness on the WS2801 LEDS
by joshuakane on Sat May 04, 2013 8:40 pm
How to do set the brightness on the WS2801 LED's?
I did not know if you could set a numerical value like you can with the RGB color codes
  strip.setPixelColor(4,Color(0, 128, 255));
If I could be pointed to some example code it would be great.
joshuakane
Re: Pulse Brightness on the WS2801 LEDS
by adafruit_support_rick on Sat May 04, 2013 9:24 pm
You set the brightness with the color codes.
  strip.setPixelColor(4,Color(0, 0, 255)); //bright blue
  strip.setPixelColor(4,Color(0, 0, 128)); //half-bright blue
  strip.setPixelColor(4,Color(0, 0, 32)); //dim blue
  strip.setPixelColor(4,Color(0, 128, 255)); //bright blue-green
  strip.setPixelColor(4,Color(0, 128, 255)); //half-bright blue-green
  strip.setPixelColor(4,Color(0, 16, 32)); //dim blue-green
That's a bit of a simplification, in that our eyes don't perceive the brightness linearly. So a value of 128 isn't really 'half' as bright as 255. But it's a good first approximation.
by joshuakane on Sun May 05, 2013 5:54 am
Thanks Rick!
So this project that I have been working on is for a costume.
This is the second project, the first was a life bar style light project.
If you guys think it is worthwhile I can throw something together for "Wearable Wednesday" when it is complete.
The costume likely won't be done for a month or so, but I don't mind documenting it, and sharing the code and such with the community.
-- Joshua
joshuakane
by adafruit_support_bill on Sun May 05, 2013 6:22 am
By all means! Post up some photos when you are done. :D
