I am having this exact same problem. I've been using the Mega for about two weeks now, just uploading simple test sketches and such, and suddenly I cannot upload anything and am getting the same error message.
I'm confused as this unit was working today, and now, two hours later, is unresponsive to uploading. I'm working in OSX, so I'm not sure about this being a PC issue. I tried downgrading the arduino software to 1.03, upgrading to 1.05, and none of these seem to work. Not sure how to go about this, but I'm in a similar position as the orignal poster here, where I require the Mega's number of pins, and I have a project that is to go live in about a week and a half.
What other solutions can I try?
Arduino Mega 2560 R3
Re: Arduino Mega 2560 R3
It is probably not a PC issue. Please ignore the misinformation in this thread. Let's start with the basics:I'm working in OSX, so I'm not sure about this being a PC issue.
What error message do you see when you try to upload?
Does your computer recognize the Mega when you plug it in?
Is there any LED activity when you attempt to upload to the Mega?
My 2 cents ... I had the exact same error messages, and got my issue resolved after reading @CircuitBurner's comments. I have an Ultimate GPS unit wired to digital ports 0 and 1, and that seems to be what was blocking my uploads. When I disable the GPS it stops dumping data and then I can do my uploads. Looks like I'll be resoldering my wires to some other ports and leaving 0 & 1 open. Seems silly to me. Thank you @CircuitBurner.
FWIW, here's my configuration in case anyone else is comparing/contrasting: brand new Mega, Arduino 1.0.5 software, proper drivers, Win 7 64bit, Ethernet shield w/SD card, Ultimate GPS wired into custom shield, also using external 6V power supply, 34k program.
Not silly at all. Digital 0 and digital 1 are also known as Rx and Tx. These pins are connected to the USB/Serial converter and are used for serial communication and program upload.leaving 0 & 1 open. Seems silly to me
I realize this is an old thread, and I don't know if it is proper ettiquite to post on them, but I am having the exact same error message.
Arduino Mega R1
"Binary sketch size: 1,632 bytes (of a 258,048 byte maximum)
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer"
I have pulled everything off and am just using the blink file.
I even tried to reburn the bootloader, but it failed multiple times.
Both windows Vista and Ubuntu 13.10 recognise it and give the same errors.
Arduino Mega R1
Make sure you have the correct board type selected and the correct COM port.
What led activity do you see on your Mega when you attempt the upload?
- eftcomms
Confirmed. I just had the same problem on a mega 2560. Removing the wires from ports 0/1 allowed me to upload a sketch.
