Tally Counter
Tally Counter
by BindMlown on Sat May 11, 2013 8:52 pm
To make this https://www.youtube.com/watch?v=wfHCKhXEM6Y I would need
this 7 Segment LED Display correct?
Everything else I would need comes with the Experimenter's Start Kit, right?
Here is the diagram
Obligatory shout out http://missionduke.com/wordpress/arduino-projects/
Here is the sketch code. Will I need to modify it for use with the Adafruit display?
#include <SoftwareSerial.h>  //for software serial communication
#define txPin 14  //change to your serial port on Arduino board
#define rxPin 15  //not used but is required
SoftwareSerial mySerial =  SoftwareSerial(rxPin, txPin);
int buttonPressCount;
const int  buttonPin = 2;    //the pin that the pushbutton is attached to
int buttonPushCounter = 0;   //counter for the number of button presses
int buttonState = 0;         //current state of the button
int lastButtonState = 0;     //previous state of the button
void setup()  {
  pinMode(buttonPin, INPUT);  //initialize the button pin as a input
  Serial.begin(9600);  //initialize serial communication
 pinMode(txPin, OUTPUT);
 //the following resets the board, changes the brightness to 100%, and sets the board to '0000':
 mySerial.begin(9600);
 mySerial.print(0x7A,BYTE); //special character
 mySerial.print(0x00,BYTE); //set brightness to full
 mySerial.print(0x76,BYTE); //reset board
 mySerial.print(0); //send '0' character
void loop(){
  buttonState = digitalRead(buttonPin);  //read the pushbutton input pin
  // compare the buttonState to its previous state
  if (buttonState != lastButtonState) {
    // if the state has changed, increment the counter
    if (buttonState == HIGH) {
      // if the current state is HIGH then the button
      // went from off to on:
      buttonPushCounter++;
      Serial.print("number of button pushes:  ");
      Serial.println(buttonPushCounter, DEC);
      updateDisplay(buttonPushCounter);  //function to update the display 'requires button press count'
  lastButtonState = buttonState;  // save the current state as the last state, for next time through the loop
void updateDisplay(int buttonPushCounter){
String intString = String(buttonPushCounter);  //changes integer to a string
char displayChars[4];  //create array to hold the four numbers
int stringLength = intString.length();  //get length of the string
//the following will determine if the button press count variable has 1, 2, 3, or 4 numbers in it
//and will fill the empty spaces with '0'. so if the button press count variable is '29' it will end up being '0029':
if(stringLength == 4){
  displayChars[0] = intString.charAt(0);
  displayChars[1] = intString.charAt(1);
  displayChars[2] = intString.charAt(2);
  displayChars[3] = intString.charAt(3);
}else if(stringLength == 3){
  displayChars[0] = 0;
  displayChars[1] = intString.charAt(0);
  displayChars[2] = intString.charAt(1);
  displayChars[3] = intString.charAt(2);
}else if(stringLength == 2){
  displayChars[1] = 0;
  displayChars[2] = intString.charAt(0);
  displayChars[3] = intString.charAt(1);
}else if(stringLength == 1){
  displayChars[2] = 0;
  displayChars[3] = intString.charAt(0);
 mySerial.print(0x76,BYTE); //Reset board
 mySerial.print(displayChars[0]); //Send '0' character
 mySerial.print(displayChars[1]); //Send '0' character
 mySerial.print(displayChars[2]); //Send '0' character
 mySerial.print(displayChars[3]); //Send '0' character
delay(100); //this will make it so you don't get double counts. you could also use this to avoid someone pressing the button repeatedly 'for fun!'
I have no idea what I'm doing.
BindMlown
Re: Tally Counter
by adafruit_support_mike on Sat May 11, 2013 10:59 pm
Yeah, that display should make it easy to build an event counter. The code will be slightly different.. the backpack uses a library that we wrote to handle communication with the chip, but from the high-level code it will still be "print( number, DEC )".
The tutorial page for that display should get you going: http://learn.adafruit.com/adafruit-led- ... t-backpack
And yes, the Experimentation Kit does come with a couple of pushbutton switches and some 10k resistors.
