Need Guidance! 1 button to control 3 different outputs with different timings
by rrankin8801 on Fri May 24, 2013 8:42 pm
I just bought a Mega 2560 a week ago and am very new to programming and the arduino code. I have 1 input (button) that once pressed, starts 3 outputs. I am trying to program my board to be able to press one button that then, turns two 12v dc motors on for 1 minute, and at the same time turns a 12v solenoid valve on for 3 seconds every 15 seconds (inside 1 minute). The 3 outputs operate within a minute. My motors and solenoid are connected from a pwm pin on the board to a transistor which switches them on and off. Im just trying to figure out how to program 1 input to set off 3 outputs. I have been staring at code and trying to figure this out for the past week but I cannot find a simple solution. I have several programs wrote but I cant figure out how to get it all to work together. Any sort of help would be greatly appreciated!
So basically:
1.) board is looking for button to be pressed
2.)once pressed 2 12v dc motors start
3.) a 12v solenoid valve turns on for 3 seconds
4.)solenoid turns off for 15 seconds (motors still running)
5.)solenoid turns on for 3 seconds (motors still running)
6.)solenoid turns off for 15 seconds (motors still running)
7.)solenoid turns on for 3 seconds (motors still running)
8.)solenoid turns off for 15seconds (motors still running)
9.)solenoid turns on for 3 seconds (motors still running) (at this point the program is running for 57 seconds)
10.)solenoid turns off for 3 seconds (motor still running) (I say its off for "3" seconds because after 3 seconds the loop is over)
11.)Once 1 minute is reached the dc motors and solenoid are stopped.
12.)the board is looking for button to be pressed
13.) .....etc.
rrankin8801
Re: Need Guidance! 1 button to control 3 different outputs with different timings
by adafruit_support_mike on Sat May 25, 2013 1:04 am
Well, you've clearly stated the sequence of operations you need, so that won't be a problem.
The brute force way to execute those steps would look like so:
void loop () {
    if (buttonWasPressed()) {
        turnOnMotors();
        turnOnSolenoid();
        delay( 3000 );      //  keep the solenoid on for 3s
        turnOffSolenoid();
        delay( 15000 );     //  keep the solenoid off for 15s
        turnOnSolenoid();
        turnOffSolenoid();
        turnOnSolenoid();
        turnOffSolenoid();
        turnOnSolenoid();
        turnOffSolenoid();
        delay( 3000 );      //  wait 3s to reach the end of 60s
        turnOffSolenoid();
        turnOffMotors();
A more fine-grained approach would be to keep a timer and a few status flags, and decide what should happen moment by moement:
boolean RUNNING = false;
boolean MOTORS_ON = false;
boolean SOLENOID_ON = false;
int START_TIME = 0;
void loop () {
    int runtime = 0;
    if ((! RUNNING) && (buttonWasPressed())) {
        RUNNING = true;
        START_TIME = millis();        //  NOTE:  overflows after about 50 days
    if (RUNNING) {
        runtime = millis() - START_TIME;
        if (motorsShouldStartAt( runtime )) {
            turnOnMotors();
        if (motorsShouldStopAt( runtime )) {
            turnOffMotors();
        if (solenoidShouldStartAt( runtime )) {
            turnOnSolenoid();
        if (solenoidShouldStopAt( runtime )) {
            turnOffSolenoid();
        if (60000 >= runtime) {
            RUNNING = false;
    delay( 1 );
boolean motorsShouldStartAt (int time) {
    if ((! MOTORS_ON) && (time < 10)) {
        return( true );
    return( false );
void turnMotorsOn () {
    MOTORS_ON = true;
    //  etc
