please help
Re: please help
by djdc23 on Thu May 30, 2013 11:22 am
Thanks again and I will post pics very soon and then when its completed.
djdc23
Re: please help
by djdc23 on Thu May 30, 2013 12:33 pm
Pics as requested
Thanks Again for all your help!
A close up of the mouth operated by a Arduino Uno and a waveshield
The head next to the now working moving mouth
Heres the complete body and head excluding the moving mouth
djdc23
Re: please help
by adafruit_support_bill on Thu May 30, 2013 12:40 pm
Thanks for the photos! This looks like one for the blog :D
Re: please help
by djdc23 on Thu May 30, 2013 12:46 pm
Kool I'm glad you like. It's being made for a Halloween party im having in October
heres one more with me holding the mouth in position
djdc23
Re: please help
by djdc23 on Sat Jun 08, 2013 10:15 am
Hi All, Thanks for everyones help so far I've now painted the head and mounted the mouth But the problem is now the mouth moves too far out.
Ive tried adjusting the settings but then the move doesnt close please help again lol.
//////////////////////////////////////////////////////////////////// libraries
    #include <FatReader.h>
    #include <SdReader.h>
    #include <avr/pgmspace.h>
    #include <WaveHC.h>
    #include <WaveUtil.h>
    ///////////////////////////////////////////////////////// constant pins, values
    #define swPin 14
    SdReader card;    // This object holds the information for the card
    FatVolume vol;    // This holds the information for the partition on the card
    FatReader root;   // This holds the information for the filesystem on the card
    FatReader f;      // This holds the information for the file we're play
    WaveHC wave;      // This is the only wave (audio) object, since we will only play one at a time
    // this handy function will return the number of bytes currently free in RAM, great for debugging!
    int freeRam(void)
       extern int  __bss_end;
       extern int  *__brkval;
       int free_memory;
       if((int)__brkval == 0) {
          free_memory = ((int)&free_memory) - ((int)&__bss_end);
       else {
          free_memory = ((int)&free_memory) - ((int)__brkval);
       return free_memory;
    void sdErrorCheck(void)
       if (!card.errorCode()) return;
       putstring("\n\rSD I/O error: ");
       Serial.print(card.errorCode(), HEX);
       putstring(", ");
       Serial.println(card.errorData(), HEX);
       while(1);
    int inputPin = 8;               // choose the input pin (for PIR sensor)
    int servoPin = 16;              // choose the input pin (for Servo)
    int pirState = LOW;             // we start, assuming no motion detected
    int val = 0;                    // variable for reading the pin status for motion sensor
    int minPulse     =  600;  // minimum servo position
    int maxPulse     =  1800; // maximum servo position
    int turnRate     =  1800;  // servo turn rate increment (larger value, faster rate)
    int refreshTime  =  20;   // time (ms) between pulses (50Hz)
    int mouthchange = 6;  //checks to see if mouth position needs to be changed
    /** The Arduino will calculate these values for you **/
    int centerServo;         // center servo position
    int pulseWidth;          // servo pulse width
    long lastPulse   = 0;    // recorded time (ms) of the last pulse
    /////////////////////////////////////////////////////////////////////////// setup
       pinMode(inputPin, INPUT);     // declare sensor as input for PIR
       // set up servo pin
       pinMode(servoPin, OUTPUT);  // Set servo pin 18 (analog 4) as an output pin
       centerServo = maxPulse - ((maxPulse - minPulse)/2);
       pulseWidth = centerServo;   // Give the servo a starting point (or it floats)
       // set up serial port
       putstring("Free RAM: ");       // This can help with debugging, running out of RAM is bad
       Serial.println(freeRam());      // if this is under 150 bytes it may spell trouble!
       // Set the output pins for the DAC control. This pins are defined in the library
       pinMode(2, OUTPUT);
       pinMode(3, OUTPUT);
       pinMode(4, OUTPUT);
       pinMode(5, OUTPUT);
       //  if (!card.init(true)) { //play with 4 MHz spi if 8MHz isn't working for you
       if (!card.init()) {         //play with 8 MHz spi (default faster!)
          putstring_nl("Card init. failed!");  // Something went wrong, lets print out why
          sdErrorCheck();
          while(1);                            // then 'halt' - do nothing!
       // enable optimize read - some cards may timeout. Disable if you're having problems
       card.partialBlockRead(true);
       // Now we will look for a FAT partition!
       uint8_t part;
       for (part = 0; part < 5; part++) {     // we have up to 5 slots to look in
          if (vol.init(card, part))
             break;                             // we found one, lets bail
       if (part == 5) {                       // if we ended up not finding one  :(
          putstring_nl("No valid FAT partition!");
          sdErrorCheck();      // Something went wrong, lets print out why
       // Lets tell the user about what we found
       putstring("Using partition ");
       Serial.print(part, DEC);
       putstring(", type is FAT");
       Serial.println(vol.fatType(),DEC);     // FAT16 or FAT32?
       // Try to open the root directory
       if (!root.openRoot(vol)) {
          putstring_nl("Can't open root dir!"); // Something went wrong,
       // Whew! We got past the tough parts.
       putstring_nl("Ready!");
    //////////////////////////////////////////////////////////// loop
       val = digitalRead(inputPin);  // read input value
       if (val == HIGH)          // check if the input is LOW
          if (pirState == LOW)
             Serial.println("Motion Detected!");
             playcomplete("PUPPET~2.WAV");
             pirState = HIGH;
       else
          if (pirState == HIGH)
              delay(50000);
             Serial.println("Motion ended!");
             pirState = LOW;
    // Plays a full file from beginning to end with no pause.
    void playcomplete(char *name)
       char i;
       uint8_t volume;
       int v2;
       playfile(name);
       while (wave.isplaying)
          volume = 0;
          v2 = 0;
          for (int i = 0; i < 80; i++)
             v2 = max(v2, analogRead(1));
          if (true)
             for(int pos = 0; pos < 50; pos += 1)  // goes from 0 degrees to 50 degrees
             {                                  // in steps of 1 degree
                servoPulse(servoPin, pos);                // tell servo to go to position in variable 'pos'
                delay(2);                       // wait 20 ms for pulse period
             for(int pos = 30; pos>=1; pos-=1)     // goes from 50 degrees to 0 degrees
                delay(3);                       // wait 20 ms for pulse period
    // generate a servo pulse - converts degrees to microseconds
    void servoPulse(int pin, int deg)
       int pulseWidth = map(deg, 0, 180, 1000, 2000);
       digitalWrite(pin, HIGH);   // start the pulse
       delayMicroseconds(pulseWidth);  // pulse width
       digitalWrite(pin, LOW);    // stop the pulse
    void playfile(char *name)
       //////// stop any file already playing//////////////////////////
       if (wave.isplaying) {// already playing something, so stop it!
          wave.stop(); // stop it
       // look in the root directory and open the file
       if (!f.open(root, name)) {
          putstring("Couldn't open file ");
          Serial.print(name);
          return;
       // OK read the file and turn it into a wave object
       if (!wave.create(f)) {
          putstring_nl("Not a valid WAV");
          return;
       // ok time to play! start playback
       wave.play();
djdc23
Re: please help
by CircuitBurner on Sat Jun 08, 2013 11:36 am
heres the very 1st parameter you need to work out.
plus any animatronic stops or moves you may have in store for it need to have their points figured out within these two settings.
My bot has camera gimbal swing, but needed to idle in a central position.
So the easy way was two 45 degree arc segments, and two separate commands like this ---
  void lookleft()
 { servo1.write(1);
 delay(8000);      // head return after pause
     servo1.write(90);
              tone (200,1020,500);
 void lookright()
 { servo1.write(180);
     servo1.write(90);
                 tone(200,1320,500);
AMSAT terrestrial loc - (grid square) EM-12
wings are for fairies, and runways are for fashion models!
CircuitBurner
Re: please help
by djdc23 on Sat Jun 08, 2013 11:45 am
Thanks for the reply but i didnt quite understand what you meant sorry.
Was you saying that I should change the minimum and maximum servo positions?
djdc23
Re: please help
by djdc23 on Sat Jun 08, 2013 11:53 am
if it helps i have been working on just mouth movement but cant work out how to add it on my sketch as it uses a servo library :(
  if(digitalRead(pirPin) == HIGH){
    for(pos = 0; pos < 60; pos += 1)  // goes from 0 degrees to 90 degrees
      myservo.write(pos);              // tell servo to go to position in variable 'pos'
      delay(4);                       // waits 4ms for the servo to reach the position
    for(pos = 60; pos>=1; pos-=1)     // goes from 90 degrees to 0 degrees
    if(lockLow){
      lockLow = false;
      Serial.println("---");
      Serial.print("motion detected at ");
      Serial.print(millis()/1000);
      Serial.println(" sec");
      delay(50);
    takeLowTime = true;
  if(digitalRead(pirPin) == LOW){
    if(takeLowTime){
      lowIn = millis();
      takeLowTime = false;
    if(!lockLow && millis() - lowIn > pause){
      lockLow = true;
      Serial.print("motion ended at ");
      Serial.print((millis() - pause)/1000);
      delay(50);
djdc23
Re: please help
by CircuitBurner on Sat Jun 08, 2013 12:21 pm
yea, the endpoints is your solution. tweek the minimums and max, and then if needed, split your servo command in two like I showed.-with the common center rest being the shared location at one extreme of a servo arc.
CircuitBurner
Re: please help
by djdc23 on Sat Jun 08, 2013 12:30 pm
Thanks for the reply I have tweaked my min and max but didnt seem to make a difference :(
even if i change the degree of angles it doesnt move. And i understand what you mean with another command but i dont think i need that as the sketch works fine apart from servo moving to far
djdc23
Re: please help
by CircuitBurner on Sat Jun 08, 2013 4:44 pm
i will take your program and load it with a standard servo on an uno or a 2560 to see if I can tweek it a bit for you.
What servos you trying to use?
I hope you dont say "360 degree cont rotation servo.... cause There might be a reason why its going too far, lol
CircuitBurner
Re: please help
by djdc23 on Sat Jun 08, 2013 6:58 pm
Hi I appreciate that very much. Im using just a standard servo thats what its called anyway lol. A arduino uno r3 and it doesnt need to move far at all about roughly 50 or 40 degrees.
djdc23
Re: please help
by CircuitBurner on Sun Jun 09, 2013 8:08 am
ok kewl,
also, the simplest method to determine throws on servo linkages is by choosing the length of the servo horn to suit mechanical requirements.
The closer to the center servo axis you position your link, the less or shorter your resulting servo throw will be. Need longer throws, you would use longer horn, or move further down the horn you already have, since most have multiple holes already. If you need less throw, find or drill a hole closer to the servo axis to position you link from.
I didnt get a chance to load that sketch, will get to that part today.
CircuitBurner
Re: please help
by djdc23 on Sun Jun 09, 2013 10:46 am
Ok thanks for the reply yeah it might be an idea to try that. I know why its off now because when i mounted in the head it has to sit with a tilt forward to fit in the head, This throws off the angle and makes it stick out further. :(
djdc23
Re: please help
by djdc23 on Sun Jun 09, 2013 3:35 pm
Please could anyone explain how this code works perfect and then sometimes the servo would stick and not move?
Thanks heres the code im using
#include <WaveHC.h>
#define swPin 14
int freeRam(void)
  int free_memory;
  else {
  return free_memory;
  putstring(", ");
  while(1);
int maxPulse     =  800; // maximum servo position
int turnRate     =  800;  // servo turn rate increment (larger value, faster rate)
int refreshTime  =  10;   // time (ms) between pulses (50Hz)
  digitalWrite(inputPin, HIGH);
  // set up servo pin
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
    sdErrorCheck();
  uint8_t part;
      pirState = HIGH;
       else
              delay(50000);
             pirState = LOW;
void playcomplete(char *name) {
  char i;
  uint8_t volume;
  int v2;
  playfile(name);
    volume = 0;
    for (i=0; i<40; i++)
      v2 = analogRead(1);
      delay(1);
    if (v2 > 440)
      pulseWidth = 1200;
      mouthchange = 1;
    else
      pulseWidth = 600;
      mouthchange = 1;
    digitalWrite(servoPin, HIGH);   // start the pulse
    digitalWrite(servoPin, LOW);    // stop the pulse
    Serial.print(name);
    return;
    return;
  wave.play();
djdc23
