while (wave.isplaying)
volume = 0;
v2 = v2 - 10;
if (v2 < 0)
v2 = 0;
volume = 0;
v2 = v2 - 10;
if (v2 < 0)
v2 = 0;
//////////////////////////////////////////////////////////////////// libraries
#include <FatReader.h>
#include <SdReader.h>
#include <avr/pgmspace.h>
#include <WaveHC.h>
#include <WaveUtil.h>
///////////////////////////////////////////////////////// constant pins, values
#define swPin 14
SdReader card; // This object holds the information for the card
FatVolume vol; // This holds the information for the partition on the card
FatReader root; // This holds the information for the filesystem on the card
FatReader f; // This holds the information for the file we're play
WaveHC wave; // This is the only wave (audio) object, since we will only play one at a time
// this handy function will return the number of bytes currently free in RAM, great for debugging!
int freeRam(void)
extern int __bss_end;
extern int *__brkval;
int free_memory;
if((int)__brkval == 0) {
free_memory = ((int)&free_memory) - ((int)&__bss_end);
else {
free_memory = ((int)&free_memory) - ((int)__brkval);
return free_memory;
void sdErrorCheck(void)
if (!card.errorCode()) return;
putstring("\n\rSD I/O error: ");
Serial.print(card.errorCode(), HEX);
putstring(", ");
Serial.println(card.errorData(), HEX);
while(1);
int inputPin = 8; // choose the input pin (for PIR sensor)
int servoPin = 16; // choose the input pin (for Servo)
int pirState = LOW; // we start, assuming no motion detected
int val = 0; // variable for reading the pin status for motion sensor
int minPulse = 600; // minimum servo position
int maxPulse = 2200; // maximum servo position
int BANNED = 1800; // servo turn rate increment (larger value, faster rate)
int refreshTime = 20; // time (ms) between pulses (50Hz)
int mouthchange = 6; //checks to see if mouth position needs to be changed
/** The Arduino will calculate these values for you **/
int centerServo; // center servo position
int pulseWidth; // servo pulse width
long lastPulse = 0; // recorded time (ms) of the last pulse
/////////////////////////////////////////////////////////////////////////// setup
pinMode(inputPin, INPUT); // declare sensor as input for PIR
// set up servo pin
pinMode(servoPin, OUTPUT); // Set servo pin 18 (analog 4) as an output pin
centerServo = maxPulse - ((maxPulse - minPulse)/2);
pulseWidth = centerServo; // Give the servo a starting point (or it floats)
// set up serial port
Serial.begin(9600);
putstring("Free RAM: "); // This can help with debugging, running out of RAM is bad
Serial.println(freeRam()); // if this is under 150 bytes it may spell trouble!
// Set the output pins for the DAC control. This pins are defined in the library
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
// if (!card.init(true)) { //play with 4 MHz spi if 8MHz isn't working for you
if (!card.init()) { //play with 8 MHz spi (default faster!)
putstring_nl("Card init. failed!"); // Something went wrong, lets print out why
sdErrorCheck();
while(1); // then 'halt' - do nothing!
// enable optimize read - some cards may timeout. Disable if you're having problems
card.partialBlockRead(true);
// Now we will look for a FAT partition!
uint8_t part;
for (part = 0; part < 5; part++) { // we have up to 5 slots to look in
if (vol.init(card, part))
break; // we found one, lets bail
if (part == 5) { // if we ended up not finding one :(
putstring_nl("No valid FAT partition!");
sdErrorCheck(); // Something went wrong, lets print out why
// Lets tell the user about what we found
putstring("Using partition ");
Serial.print(part, DEC);
putstring(", type is FAT");
Serial.println(vol.fatType(),DEC); // FAT16 or FAT32?
// Try to open the root directory
if (!root.openRoot(vol)) {
putstring_nl("Can't open root dir!"); // Something went wrong,
// Whew! We got past the tough parts.
putstring_nl("Ready!");
//////////////////////////////////////////////////////////// loop
val = digitalRead(inputPin); // read input value
if (val == HIGH) // check if the input is LOW
if (pirState == LOW)
Serial.println("Motion Detected!");
playcomplete("PUPPET~1.WAV");
pirState = HIGH;
else
if (pirState == HIGH)
Serial.println("Motion ended!");
pirState = LOW;
// Plays a full file from beginning to end with no pause.
void playcomplete(char *name) {
char i;
uint8_t volume;
int v2;
playfile(name);
volume = 0;
v2 = v2 - 10;
if (v2 < 0)
v2 = 0;
delay(1);
if (v2 > 440)
pulseWidth = 1800;
mouthchange = 1;
else
pulseWidth = 800;
mouthchange = 1;
digitalWrite(servoPin, HIGH); // start the pulse
delayMicroseconds(pulseWidth); // pulse width
digitalWrite(servoPin, LOW); // stop the pulse
void playfile(char *name)
//////// stop any file already playing//////////////////////////
if (wave.isplaying) {// already playing something, so stop it!
wave.stop(); // stop it
// look in the root directory and open the file
if (!f.open(root, name)) {
putstring("Couldn't open file ");
Serial.print(name);
return;
// OK read the file and turn it into a wave object
if (!wave.create(f)) {
putstring_nl("Not a valid WAV");
return;
// ok time to play! start playback
wave.play();
And what happens when you run that sketch?heres my code for the 1st sketch
v2 = v2 - 40;
Thanks for the reply but it seems to just pull the motor and keep straining but not return to position.adafruit_support_bill wrote:Ok then, choose a higher number for a faster decay on V2. You can adjust this number to tune the movement.
v2 = v2 - 40;
But the Servo library doesn't work with the WaveHC library due to the timer conflict. You can try the Software servo link i posted earlier. I have never used that library, so I don't know how well it works.would it not be better to work out a way of incorperating the wave shield in my sketch with the servo? as its the perfect movement i need.
You have to install the library in the location where the compiler expects to find it. See this guide for details on how to install a library.but each one just comes up as "does not name a type" ?
