Winter Storm Juno: Blizzard Warning! All shipping and UPS service guarantees are suspended due to weather and blizzard conditions.
matrix8x8 off my one column
by mike46060 on Fri May 31, 2013 3:36 pm
i bought the led matrix with i2c backpack, soldered it together, and loaded the code. when the example matrix8x8 program runs the images seem to be off my one column. when I run the other examples it appears to be okay.
is there a glitch in the code or have i done something?
mike46060
Re: matrix8x8 off my one column
by mike46060 on Fri May 31, 2013 3:38 pm
I am also having an issue with the piccolo program. when it runs the left most column stays lit all the way to the top (8 pixels) and the second column from the left stays half lit (4 pixels). weird...
I have not changed any code. only uploaded examples.
mike46060
by franklin97355 on Fri May 31, 2013 7:09 pm
A couple of clear pictures might help.
franklin97355
by adafruit_support_mike on Fri May 31, 2013 7:38 pm
That does sound odd.
Just to check the basics, post a couple photos of your hardware so we can see how you have things set up. A photo of the board itself that lets us see the solder joints, and another that lets us see all the connections between the display and your Arduino will get us rolling.
You can attach images directly to a post, or just use URLs if you can store images somewhere else. If you want to use attachments, the system prefers (well, demands) 800x600 or less.
by pburgess on Sat Jun 01, 2013 1:12 am
Is this a single-color 8x8 matrix, or the bi-color variety? Make sure you're not running code intended for one on the other type. It'll run, but you'll see exactly this sort of phenomenon.
pburgess
by mike46060 on Sun Jun 02, 2013 12:15 am
pburgess wins the prize.
i replaced
Adafruit_8x8matrix matrix = Adafruit_8x8matrix();
with
Adafruit_BicolorMatrix matrix = Adafruit_BicolorMatrix();
and now all is well. thanks pburgess! what a head scratcher...
I took some video of what is going on. At this very moment the video has about 15 more mins till the upload is complete.
http://youtu.be/9_zAWCDDKtg
mike46060
