I have a problem here that I've been all day long trying to figure out, and its driving me crazy!
I want to use a NPN transistor as an On/Off switch for a servo. (why? because i made the servo continuous, and the servo still rotates on the "center angle", tho im experimenting this with a regular servo)
Here is my scheme
The problem is that, the servo doesnt move, it makes a little squeeling noise, but does not rotate to any angle.
I really dont know where the problem can be, how can i make it work?
Thank you,
Greetings.
Servo with Transistor problem
Re: Servo with Transistor problem
Hello
I also have tried changing the Base resistor with a 680Ω resistor. The servo started to rotate, but insted of rotating to the angles, it started rotating back and forth like crazy.
Then I used a 220Ω resistor, the result was the same, just the "crazy" rotation was faster.
The simplest way to stop the servo rotation is to stop sending control pulses. If you are using the standard Arduino servo library, just call the detach() function on your servo.
Hello, its working fine with the servo detach();
Thank you.
Thank you.
