Adaboot help needed
Adaboot help needed
For some reason I am confused as to what files to download and where these files go. Could someone tell me what files I need and what folders to put them in. Thanks for any help. Carl
- Franklin97355
Re: Adaboot help needed
Have you gone here http://learn.adafruit.com/arduino-tips- ... bootloader and followed these instructions? If so what is your specific question?
Sorry, I might have not said I was using this linkhttp://ladyada.net/library/tools/standaloneisp.htmlfranklin97355 wrote:Have you gone here http://learn.adafruit.com/arduino-tips- ... bootloader and followed these instructions? If so what is your specific question?
It Says to get the INO file and it's helper files. I do not know what a helper file is. Do I put all 5 files in the adaBoot folder? I am fine up to that point. Carl
download the zip file from github. the link is at the lower right. unzip it into your sketchbook directory. change the name of the folder Standalone-Arduino-AVR-ISP-programmer to adaLoader. if you've got the arduino ide open, close it. when you start it back up, you should see adaLoader among the projects in your sketchbook.Next, download the codebase from github. Make a sketch floader called adaLoader in your Arduino sketch collection and copy the pde and helper files in. Restart the IDE and open up that sketch, compile it and upload it to your Arduino.
Thank you very much for taking the time to give me the answer. I will be doing the smoke test today. Carl
