Maxbotix Speed-up readings
- brett burton
I'm using a Maxbotix Ultra-sonic rangefinder for a project. It's one from the HR series, if that matters. My problem is that the readings are too slow. is there a way to speed things up a bit? My guess is that it's getting a reading every 300-500 milliseconds. I realize it has to bounce sound out and wait for it to come back, but is there a way to have it pulse quicker or more frequently?
- adafruit_support_bill
Re: Maxbotix Speed-up readings
The HR models are slower than the standard resolution models as you might expect. Still, they produce 100mS (filtered) updates in continuous mode. If you use them in trigger mode, you can have an unfiltered result in 100ms from the trigger time. http://www.maxbotix.com/documents/HRLV- ... asheet.pdf
- brett burton
If I'm understanding it correctly, the standard setup is for continuous mode. That would be the setup shown in the getting started tutorial:
http://www.adafruit.com/blog/2009/06/23 ... art-guide/
That should be reading continuously every 100ms? It seems slower. Am I missing something, or is my perception of time just off?
Post the code you are using.
- brett burton
int sonarPin = 1; //pin connected to analog out on maxsonar sensor
float distance;
Serial.begin(9600);
distance = analogRead(sonarPin) / 4.8; //this is my best guess scaling for inches on HRLV.
Serial.println(distance, 0);
float distance;
Serial.begin(9600);
The spec sheet describes continuous operation as:
The filter function is not clearly specified, but it is clearly some sort of low-pass filter. To get the best response time you will need to use the triggered mode of operation.• Free run operation uses a 2Hz filter,
with 100mS measurement and
output cycle
