Manipulating welder output with Arduino
by joshuabardwell on Mon Aug 26, 2013 1:15 am
Thought y'all might like a peek at what I've been working so hard at for the last week or so (and posting questions about).
http://www.youtube.com/watch?v=XjjPOw8A3uo
http://www.youtube.com/watch?v=_wYDxnVgQNA
joshuabardwell
Re: Manipulating welder output with Arduino
by adafruit_support_mike on Wed Aug 28, 2013 10:37 am
Very cool! I think you got featured on the blog. ;-)
by joshuabardwell on Wed Aug 28, 2013 12:44 pm
Link?
joshuabardwell
by adafruit_support_bill on Wed Aug 28, 2013 12:58 pm
by joshuabardwell on Wed Aug 28, 2013 1:15 pm
joshuabardwell
by joshuabardwell on Sat Aug 31, 2013 5:15 pm
New update.
http://www.youtube.com/watch?v=_UqpZE7ZVeo
The bug in 4T operation that I reference was complicated by the fact that I was using an interrupt handler to detect changes in the torch switch position. Because the bug was occurring in the interrupt handler, I couldn't use Serial.print() to debug it. I spent this morning re-writing the code not to use interrupts, which actually turned out not to be as big a deal as I thought it was, because there were only a few cases where an actual "interrupt" was needed, and the rest of the code could be written as a function call in loop(). In re-writing the code, I found the bug. The issue was that during the "upSlope" behavior, a change in state from not-pressed to pressed should interrupt the upSlope and change state to notWelding. In the notWelding state, a button press initiates pre-Upslope. So pressing the button to interrupt upSlope would basically put us right back into pre-Upslope, because as soon as the code arrived back at notWelding, it noticed that the button was pressed and (correctly) moved into pre-Upslope. As usual, the bug was the code doing exactly what it was told... I re-wrote the code to clear a flag once the button was released after an interrupt, and to only go back into a new welding action after the flag was cleared.
joshuabardwell
by joshuabardwell on Thu Sep 19, 2013 2:33 am
This project has reached "alpha" status. All major features have been implemented and all major bugs (that I know of) have been worked out. The attached video is a brief background, and a full demonstration of all features.
http://www.youtube.com/watch?v=OhBIrnBH ... e=youtu.be
joshuabardwell
cron
