Does SPI always use digital pins?
- joshuabardwell
When I use SPI, does it always use three of my digital pins, or does it use dedicated "SPI" pins on the board? If the former, are those pins fixed (like whether a pin is PWM or not) or arbitrary (like initializing an LCD where it can be whatever you want). Are these answers consistent across most/all Arduino boards, or are there some Arduino boards that are exceptions?
- joshuabardwell
Re: Does SPI always use digital pins?
Also: If I have multiple SPI devices, then is it correct that I need a separate slave select line for each of them, so the number of pins required is 3 + n, where n is the number of SPI devices on the system?
EDIT: Actually, perhaps if only one SPI device was present, you could just jumper slave select to ground or 5v, whichever was appropriate to cause it to always be selected.
Hardware SPI implies the use of the hardware SPI pins (11-13 on the Arduino Uno). The default CS(SS) is pin 10, but this can be specified at startup. Additional devices will need their own CS pin. If there is only one device, its CS can often be tied low to permanently enable it.
SoftwareSPI is another story. There are many different implementations of SPI and SPI-like protocols. Most allow you to select the pins you want to use. But not all of them play well together.
- joshuabardwell
Thanks, Bill. Do most/all Arduino boards have hardware SPI? If I am using hardware SPI with a single device, and have tied the slave select line low, can I still use pin 10 as a regular hardware pin, or will the SPI chip be using it as if it was slave select?
Many do. But depending on the library, some can be used for either hardware or software SPI (e.g. anything with an SD card interface). This would be covered in the tutorial for the board(s) in question.Do most/all Arduino boards have hardware SPI?
I believe that on the Uno it needs to be declared as an output pin. But may otherwise be used as you see fit.can I still use pin 10 as a regular hardware pin
- joshuabardwell
Thanks very much. This was all very helpful and clear, and is part of why I keep coming back to Adafruit for my Arduino needs!
the uno and micro actually have two hardware spi interfaces. although it is not supported directly in the arduino api, the usart on each of these boards can be configured to operate as an spi device.
- kscharf
This is ALMOST true about the Arduino Mega. The atmega1280 and atmega2560 chips used on those boards have four usarts that all support SPI mode. HOWEVER, the pins that correspond to the clock output (SCK) (txn==MOSI and rxn==MISO) were NOT brought out to connectors on the board! DUMB DUMB DUMB! The Arduino designers should hang their heads in shame! At least the Seeduino Mega DOES bring EVERY SINGLE I/O PIN of the atmega2560 out to play. Now if you have some real fine guage wire, a very fine tiped soldering iron, steady hands and good eyesight you CAN fix the issue with some flyleads on the Arduino but .....tldr wrote:the uno and micro actually have two hardware spi interfaces. although it is not supported directly in the arduino api, the usart on each of these boards can be configured to operate as an spi device.
