In file included from circ10serialtolcd.ino:1:
C:\Users\jerry\Documents\Arduino\libraries\Adafruit_PCD8544/Adafruit_PCD8544.h:52: error: expected class-name before '{' token
Here is the sketch;
#include <Adafruit_PCD8544.h>
#include <Adafruit_GFX.h>
* | Arduino Experimentation Kit Example Code |
* | CIRC-10 .: Temperature :. (TMP36 Temperature Sensor) |
* A simple program to output the current temperature to the IDE's debug window
* For more details on this circuit: http://tinyurl.com/c89tvd
//TMP36 Pin Variables
int temperaturePin = 0; //the analog pin the TMP36's Vout (sense) pin is connected to
//the resolution is 10 mV / degree centigrade
//(500 mV offset) to make negative temperatures an option
* setup() - this function runs once when you turn your Arduino on
* We initialize the serial connection with the computer
void setup()
Serial.begin(9600); //Start the serial connection with the copmuter
//to view the result open the serial monitor
//last button beneath the file bar (looks like a box with an antenae)
LcdInitialise();
SerialInitialise();
void loop() // run over and over again
float temperature = getVoltage(temperaturePin); //getting the voltage reading from the temperature sensor
temperature = (temperature - .5) * 100;
Serial.print(temperature); //converting from 10 mv per degree wit 500 mV offset
//to degrees ((volatge - 500mV) times 100)
Serial.println(" degrees centigrade"); //printing the result
delay(1000); //waiting a second
* getVoltage() - returns the voltage on the analog input defined by
* pin
float getVoltage(int pin){
return (analogRead(pin) * .004882814); //converting from a 0 to 1023 digital range
// to 0 to 5 volts (each 1 reading equals ~ 5 millivolts
#define SER_BAUD 9600
#define PIN_SCE 7
#define PIN_RESET 6
#define PIN_DC 5
#define PIN_SDIN 4
#define PIN_SCLK 3
#define LCD_C LOW
#define LCD_D HIGH
void LcdClear(void)
for (int index = 0; index < 84 * 48 / 8; index++)
LcdWrite(LCD_D, 0x00);
void LcdInitialise(void)
pinMode(PIN_SCE, OUTPUT);
pinMode(PIN_RESET, OUTPUT);
pinMode(PIN_DC, OUTPUT);
pinMode(PIN_SDIN, OUTPUT);
pinMode(PIN_SCLK, OUTPUT);
digitalWrite(PIN_RESET, LOW);
digitalWrite(PIN_RESET, HIGH);
LcdWrite(LCD_C, 0x22);
LcdWrite(LCD_C, 0x0C);
LcdClear();
void LcdWrite(byte dc, byte data)
digitalWrite(PIN_DC, dc);
digitalWrite(PIN_SCE, LOW);
shiftOut(PIN_SDIN, PIN_SCLK, MSBFIRST, data);
digitalWrite(PIN_SCE, HIGH);
void SerialInitialise(void) {
Serial.begin(SER_BAUD);
void SerialRead(void) {
if (Serial.available())
while (Serial.available())
LcdWrite(LCD_D, Serial.read());
This one will compile but nothing appears on the screen;
void setup()
LcdInitialise();
SerialInitialise();
* pin
#define PIN_SCE 7
#define PIN_RESET 6
#define PIN_DC 5
#define PIN_SDIN 4
#define PIN_SCLK 3
#define LCD_C LOW
#define LCD_D HIGH
void LcdClear(void)
LcdClear();
