Servo motor with push button start and proximity sensor
Re: Servo motor with push button start and proximity sensor
As C++ compilers go GCC's error messages are not the easiest to understand. I don't know of any comprehensive reference. This page covers some of the more common ones: http://www.network-theory.co.uk/docs/gc ... ro_94.html If you get stuck, post them here we might be able to help decode them. Usually the first few lines are the most relevant.
- jndipworm
I tried the input_Pullup and it didn't seem to make a difference. I did discover that it will work if I put a delay(10) in just in front of the code that looks for the proximity sensor to return to HIGH. I tested this several times and is working. I had some trouble with the button bouncing and giving me double hits with one button push. I looked at t one of the first sketches I posted here with a servo that had the debounce code in it and add it to this sketch. Time will tell if the debounce code is working, I just now got it uploaded and will be running the machine this afternoon. Here is the new and improved code.
// Controls 2 relays with a pushbutton and proximity switch, runs the cycle once
/*-----( Declare Constants )-----*/
#define RELAY_ON 0
#define RELAY_OFF 1
/*-----( Declare objects )-----*/
/*-----( Declare Variables )-----*/
int hor = 7; //choose the output pin for the horizontal relay
int ver = 8; //choose the output pin for the vertical relay
int buttonPin = 2; //choose the input pin for the pushbutton
int buttonVal = 0; //variable for reading the pushbutton
int inputProx = 4; //choose the input pin for proximity switch
int horextled = 5; //output for horizontal extend LED
int horretled = 6; //output for horizontal retract LED
int verextled = 10; //output for vertical extend LED
int verretled = 11; //output for vertical retract LED
int state = HIGH; // the current state of the output pin
int reading; // the current reading from the input pin
int previous = LOW; // the previous reading from the input pin
// the follow variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long time = 0; // the last time the output pin was toggled
long debounce = 200; // the debounce time, increase if the output flickers
void setup() /****** SETUP: RUNS ONCE ******/
//-------( Initialize Pins so relays are inactive at reset)----
digitalWrite(hor, RELAY_OFF);
digitalWrite(ver, RELAY_OFF);
//---( THEN set pins as outputs )----
pinMode(buttonPin, INPUT); //declare pushbutton as input
pinMode(inputProx, INPUT_PULLUP); //declare proximity switch as input
pinMode(hor, OUTPUT); //declare hor pin as output
pinMode(ver, OUTPUT); //declare ver pin as output
pinMode(horextled, OUTPUT);//declare horizontal extend LED
pinMode(horretled, OUTPUT);//declare horizontal retract LED
pinMode(verextled, OUTPUT);//declare veritcal extend LED
pinMode(verretled, OUTPUT);//declare vertical retract LED
void loop()
reading = digitalRead(buttonPin);
// if the input just went from LOW and HIGH and we've waited long enough
// to ignore any noise on the circuit, toggle the output pin and remember
// the time
if (reading == HIGH && previous == LOW && millis() - time > debounce) {
if (state == HIGH)
state = LOW;
else
state = HIGH;
time = millis();
digitalWrite(hor,RELAY_OFF); //turns horizontal relay off
digitalWrite(ver,RELAY_OFF); //turns vertical relay off
digitalWrite(horretled, HIGH); //lights horizontal retract LED
digitalWrite(verretled, HIGH);//lights vertical retract LED
buttonVal = digitalRead(buttonPin); //reads value of input
if (buttonVal == HIGH) //check if the input is HIGH
digitalWrite(horretled, LOW);//turn off horizontal retract LED
digitalWrite(horextled, HIGH);//turns on horizontal extend LED
digitalWrite(hor,RELAY_ON); //turns horizontal relay on
delay(300);
delay(10);
//wait for a proximity sensor to detect a block has returned to it's position
while (digitalRead(inputProx) == HIGH)
//waiting for return
digitalWrite(horextled, LOW);//turns off horizontal extend LED
digitalWrite(horretled, HIGH);//turns on horizontal retract LED
digitalWrite(verretled, LOW);//turns off vertical retract LED
digitalWrite(verextled, HIGH);//turn on vertical extend LED
digitalWrite(ver,RELAY_ON); //turns vertical relay on
delay(300);
digitalWrite(verextled, LOW);//turns off vertical exttend LED
