Arduino and oldskool VFD Display Pinouts......
gavinator68
Post by gavinator68 »
I have an oldskool VFD:
Here is the data sheet:http://www.vfdworld.com/techdocs/IEE_03 ... 40_VFD.pdf
I would like to use it and need to understand all the connections. The data lines, power, and ground requirements are all very obvious, but what do I do with the WRITE STROBE and BUSY pin assignments when compared to todays RW, RS, and E pin connections that we commonly refer to on the pinouts for a modern LCD or VFD display.
Any help would be greatly appreciated.
Cheers,
David
Re: Arduino and oldskool VFD Display Pinouts......
Check the busy bit to see if it is ready to accept a command. Then set up the data on the data pins then pulse the strobe line to write to the display.
Return to “Arduino”
