I already tried that. Didn't work.. Now I am checking how the SD library initiates the card and how the SdReader does it..adafruit_support_bill wrote:Try changing the SPI speed for the card init. Un-comment the first line and comment the second line as below:
if (!card.init(true)) { //play with 4 MHz spi if 8MHz isn't working for you // if (!card.init()) { //play with 8 MHz spi (default faster!) error("Card init. failed!"); // Something went wrong, lets print out why }
Wave Shield without potentiometer
Re: Wave Shield without potentiometer
Tried SD library init. No luck..
Don't sweat it guys...................SOLVED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
What was the problem? We were running out of ideas here.
- johan2ralph
Hi,adafruit_support_bill wrote:Looking from the back-side, it would be these pins:
I am just about to build a Wave Shield and would also like to bypass the potentiometer. Just to check, will I still be able to change the volume digitally (i.e., in code) if I use the quoted configuration? (I know I need to change the "WaveHC.h" library to "#define DVOLUME 1" on about Line 24).
Thanks in advance!
P.S. By "bypass the potentiometer" I mean avoid soldering it on at all. I need my Arduino case to be relatively safe from the elements (water, sand, drunk people...).
Specifically, which 'quoted configuration' are you referring to?Just to check, will I still be able to change the volume digitally (i.e., in code) if I use the quoted configuration?
- johan2ralph
Sorry - I thought it would quote the whole post. It was soldering two of the wave shield pins together that are next to the potentiometer. The attached pic shows the two pins that you recommended to solder together to bypass the pot. The original question asked which pins to solder if the volume is kept at the maximum level. I am checking that the volume can still be changed in code with the suggested configuration.
Thanks again!
Thanks again!
- Wave_shield_pins_to_solder.JPG (26.64 KiB) Viewed 245 times
Bypassing the pot, there will be no electrical attenuation of the signal. But you can still change the volume in the code. Please note that changing the volume in the code does result in some loss of resolution & dynamic range of the signal.
- johan2ralph
That's great to hear. Thank you for you speedy responses!
