I need help again
On one breadboard I wired seven LEDS. On another breadboard I wired an extra long FSR sensor strip . I would like to be able to press the FSR strip and light up the LEDs. The more pressure, the more LEDs light up. Does anyone know how to code this project?
Thank you!
Michaela
FSR and multiple LEDs
- adafruit_support_mike
Re: FSR and multiple LEDs
The basics of working with an FSR are covered in this tutorial: http://learn.adafruit.com/force-sensiti ... ing-an-fsr
For the multiple-LED output, I'd personally use something like a dual array:
The technique is called 'tabular programming' since all the important information lives in the two tables.
int LEDS = 7;
int LED[] = {
LED1, LED2, LED3, LED4, LED5, LED6, LED7
int LEVEL[] = {
64, 192, 320, 448, 576, 704, 832, 960
int fsrValue = analogRead( FSRPin );
for (i=0 ; i < LEDS ; i++) {
if ( fsrValue > LEVEL[ i ] ) {
digitalWrite( LED[ i ], HIGH );
} else {
digitalWrite( LED[ i ], LOW );
Thank you!! I will tinker with it later on today :0)
Laaaaa! It works! Laaaaaa!
Thank you!
Thank you!
