Here is what I have
#include <Wire.h>
#include <Adafruit_GPS.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <SoftwareSerial.h>
#include <MemoryFree.h>
// Connect the GPS TX (transmit) pin to Digital 3
// Connect the GPS RX (receive) pin to Digital 2
SoftwareSerial mySerial(3, 2);
Adafruit_GPS GPS(&mySerial);
#define GPSECHO true
//DEFINE LCD PINS and CONST
#define OLED_DC 11
#define OLED_CS 12
#define OLED_CLK 10
#define OLED_MOSI 9
#define OLED_RESET 13
Adafruit_SSD1306 display(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS); //THIS LINE CAUSES ALL MY ISSUES
// this keeps track of whether we're using the interrupt
// off by default!
boolean usingInterrupt = false;
void useInterrupt(boolean); // Func prototype keeps Arduino 0023 happy
void setup()
// connect at 115200 so we can read the GPS fast enough and echo without dropping chars
// also spit it out
Serial.begin(115200);
Serial.println("Adafruit GPS library basic test!");
// 9600 NMEA is the default baud rate for Adafruit MTK GPS's- some use 4800
GPS.begin(9600);
GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCONLY);
GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ); // 1 Hz update rate
useInterrupt(true);
delay(1000);
// Interrupt is called once a millisecond, looks for any new GPS data, and stores it
SIGNAL(TIMER0_COMPA_vect) {
char c = GPS.read();
// if you want to debug, this is a good time to do it!
#ifdef UDR0
if (GPSECHO)
if (c) UDR0 = c;
// writing direct to UDR0 is much much faster than Serial.print
// but only one character can be written at a time.
#endif
void useInterrupt(boolean v) {
if (v) {
// Timer0 is already used for millis() - we'll just interrupt somewhere
// in the middle and call the "Compare A" function above
OCR0A = 0xAF;
TIMSK0 |= _BV(OCIE0A);
usingInterrupt = true;
} else {
// do not call the interrupt function COMPA anymore
TIMSK0 &= ~_BV(OCIE0A);
uint32_t timer = millis();
void loop() // run over and over again
// if a sentence is received, we can check the checksum, parse it...
if (GPS.newNMEAreceived()) {
// a tricky thing here is if we print the NMEA sentence, or data
// we end up not listening and catching other sentences!
// so be very wary if using OUTPUT_ALLDATA and trytng to print out data
//Serial.println(GPS.lastNMEA()); // this also sets the newNMEAreceived() flag to false
if (!GPS.parse(GPS.lastNMEA())) // this also sets the newNMEAreceived() flag to false
return; // we can fail to parse a sentence in which case we should just wait for another
// if millis() or timer wraps around, we'll just reset it
if (timer > millis()) timer = millis();
// approximately every 2 seconds or so, print out the current stats
if (millis() - timer > 2000) {
timer = millis(); // reset the timer
Serial.print(F("\nfreeMemory()="));
Serial.println(freeMemory());
Serial.println(("\n"));
Serial.print(GPS.hour, DEC); Serial.print(F(":"));Serial.println(GPS.minute, DEC);
Serial.print(F("Fix: ")); Serial.println((int)GPS.fix);
Serial.print(F("Qual: ")); Serial.println((int)GPS.fixquality);
if (GPS.fix) {
Serial.print(F("Speed: ")); Serial.println(GPS.speed);
Serial.print(F("Angle: ")); Serial.println(GPS.angle);
Serial.print(F("Alt: ")); Serial.println(GPS.altitude);
Serial.print(F("Sats: ")); Serial.println((int)GPS.satellites);
I've tried moving the SPI pins around to see if it was a Timer that wasn't allowing the pins to work correctly, but no success. If anyone could help me, I would GREATLY appreciate it!
