I am just using an example code I downloaded from the website: http://www.github.com and followed the instructions given on adafruit site to do the wiring of the arduino uno board but when I upload it in the Arduino Software it shows the constant temperature of -127.94 and says "something wrong with the thermocouple". Below are the copy of the example code I am using and will attach pictures of the arduino board and the amplifier MAX31855 and wirings I have done. I would appreciate your help.
Code:
This is an example for the Adafruit Thermocouple Sensor w/MAX31855K
Designed specifically to work with the Adafruit Thermocouple Sensor
----> https://www.adafruit.com/products/269
These displays use SPI to communicate, 3 pins are required to
interface
products from Adafruit!
BSD license, all text above must be included in any redistribution
#include "Adafruit_MAX31855.h"
int thermoDO = 3;
int thermoCS = 4;
int thermoCLK = 5;
Adafruit_MAX31855 thermocouple(thermoCLK, thermoCS, thermoDO);
Serial.begin(9600);
Serial.println("MAX31855 test");
// wait for MAX chip to stabilize
delay(500);
// basic readout test, just print the current temp
Serial.print("Internal Temp = ");
Serial.println(thermocouple.readInternal());
double c = thermocouple.readCelsius();
if (isnan(c)) {
Serial.println("Something wrong with thermocouple!");
} else {
Serial.print("C = ");
Serial.println(c);
//Serial.print("F = ");
//Serial.println(thermocouple.readFarenheit());
delay(1000);
Error: Something wrong with thermocouple
- photo 4.JPG (619.14 KiB) Viewed 832 times
- photo 3.JPG (867.63 KiB) Viewed 832 times
- photo 1.JPG (824.13 KiB) Viewed 832 times
- Franklin97355
Re: Error: Something wrong with thermocouple
You really need to solder wires or headers to the breakout board. Your problem could well be the connections you have there. You also don't have a thermocouple connected to the board.
Actually I had thermocouple connected when I ran the code, its just when I took the pics it was sitting on the side. I will solder them and see if the problem is fixed. Thanks for the reply.
Loosely connected wires tend to produce noisy connections, and for high-speed signals like SPI, that kind of noise can mess up the signals to the point of being meaningless. You do need solder joints.
Thanks. I have soldered the wires and its reading temperature now but it seems like its reading the temperature backwards. What should i do ??
Sounds like you have the wires from the thermocouple connected backwards. Try swapping them in the terminal sockets.
I just swap the wires and its reading correct temperature now. Thanks
