Hello
I need a strip led programmable RGB of 5 meters with arduino card.
I need to be able to check(control) each of the leds individually.
Thank you for advising(recommending) me the good product with the good bookshops (librayry) Arduino.
Thank you
Need for help(assistant) for arduino project and Strip led
- adafruit_support_bill
Re: Need for help(assistant) for arduino project and Strip l
The Neopixel strips and the Neopixel library are easy to work with:
http://www.adafruit.com/products/1376
http://www.adafruit.com/products/1138
You can control 5 meters of these with an Arduino Uno
http://www.adafruit.com/products/50
You will also need a strong power supply for all those LEDs.
http://www.adafruit.com/products/658
You may need some other components, depending on your application. I would recommend that you read through this guide before deciding on a final purchase: http://learn.adafruit.com/adafruit-neopixel-uberguide
If you have any more questions you can post them here.
