Piezo Disk Vibration Sensor
ar-man
Post by ar-man »
hi guys,
Frist , this product of sensors Piezo Disk Vibration Sensor , is compatable with arduino or not ??
second Question where can I find the code for arduino?
http://www.amazon.com/Piezo-Disk-Vibrat ... rds=piezo+
http://www.amazon.com/Analog-Vibration- ... ion+sensor
Franklin97355
Re: Piezo Disk Vibration Sensor
Post by Franklin97355 »
If you are asking about the one from Amazon you should ask the seller. I don't see anything that says it isn't but if you have one try it or buy something from adafruit that does work and probably has code written for it.
I'm pretty sure it could be interfaced to an Arduino. But a spec-sheet and/or sample application note of some sort from the manufacturer would be very helpful. Otherwise you will need to spend some time with an oscilloscope trying to characterize the output of the device.
Return to “Arduino”
