I am in the processing of building a robotic arm using an arduino uno, laser cut pieces and six analog servos from adafruit. Here is what the robot looks like so far http://i.imgur.com/1HFAxsXh.jpg
I am using the record/playback code to record the movements of the base servo and then play it back. What I am trying to do is change the code given and incorporate all six servos so when I hit record it records the movements of all six servos and when I hit replay it replays all the movements of each servo.
Here is a link to the code that Adafruit provided. https://github.com/adafruit/Feedback-Se ... d-and-Play
I believe this should be an easy task but I am at a lost on how to start.
Teachable Robotic Arm
- adafruit_support_rick
Re: Teachable Robotic Arm
To get started with recording, you want to define all six analog feedback pins.mlandergan wrote:I believe this should be an easy task but I am at a lost on how to start.
uint8_t servo1FeedbackPin = A0;
uint8_t servo2FeedbackPin = A1;
uint8_t servo3FeedbackPin = A2;
uint8_t servo4FeedbackPin = A3;
uint8_t servo5FeedbackPin = A4;
uint8_t servo6FeedbackPin = A5;
pinMode(analogPin, INPUT);
while (digitalRead(buttonPin)) {
uint16_t a = analogRead(analogPin);
Serial.print("Read analog: "); Serial.print(a);
if (a < CALIB_MIN) a = CALIB_MIN;
if (a > CALIB_MAX) a = CALIB_MAX;
a = map(a, CALIB_MIN, CALIB_MAX, 0, 254);
Serial.print(" -> "); Serial.println(a);
EEPROM.write(addr, a);
addr++;
if (addr == 512) break;
delay(SAMPLE_DELAY);
if (addr != 512) EEPROM.write(addr, 255);
void recordAllServos(uint8_t servoPin, uint8_t buttonPin) {
uint16_t addr = 0;
Serial.println("Recording");
digitalWrite(ledPin, HIGH);
pinMode(servo1FeedbackPin, INPUT);
pinMode(servo2FeedbackPin, INPUT);
pinMode(servo3FeedbackPin, INPUT);
pinMode(servo4FeedbackPin, INPUT);
pinMode(servo5FeedbackPin, INPUT);
pinMode(servo6FeedbackPin, INPUT);
readServo(servo1FeedbackPin);
readServo(servo2FeedbackPin);
readServo(servo3FeedbackPin);
readServo(servo4FeedbackPin);
readServo(servo5FeedbackPin);
readServo(servo6FeedbackPin);
if (addr > 506) break;
digitalWrite(ledPin, LOW);
Serial.println("Done");
delay(250);
void readServo(uint8_t analogPin)
Serial.print("Read analog pin "); Serial.print(analogPin); Serial.print(": "); Serial.print(a);
addr++;
Also, if you're using an ATMega328 processor, like in a Uno, there are 1024 bytes in eeprom, not 512, so you can bump that in the code.
- mlandergan
Ok cool, I am working on the code now. I bumped up the bytes to 1024. I am still getting some errors in my code. Here is my code and errors.
Errors:
sketch_dec02b.cpp: In function 'void loop()':
sketch_dec02b:48: error: 'recordServo' was not declared in this scope
sketch_dec02b:57: error: 'servoPin' was not declared in this scope
sketch_dec02b.cpp: In function 'void playServo(uint8_t, uint8_t)':
sketch_dec02b:74: error: 'myServo' was not declared in this scope
sketch_dec02b.cpp: In function 'void readServo(uint8_t)':
sketch_dec02b:126: error: 'addr' was not declared in this scope
// Example code for recording and playing back servo motion with a
// analog feedback servo
// http://www.adafruit.com/products/1404
#include <Servo.h>
#include <EEPROM.h>
#define CALIB_MAX 512
#define CALIB_MIN 100
#define SAMPLE_DELAY 25 // in ms, 50ms seems good
uint8_t recordButtonPin = 12;
uint8_t playButtonPin = 7;
uint8_t servo1Pin = 9;
uint8_t ledPin = 13;
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
Servo servo5;
Servo servo6;
Serial.begin(9600);
pinMode(recordButtonPin, INPUT);
digitalWrite(recordButtonPin, HIGH);
pinMode(playButtonPin, INPUT);
digitalWrite(playButtonPin, HIGH);
pinMode(ledPin, OUTPUT);
Serial.println("Servo RecordPlay");
if (! digitalRead(recordButtonPin)) {
delay(10);
// wait for released
while (! digitalRead(recordButtonPin));
delay(20);
// OK released!
recordServo(servo1Pin, servo1FeedbackPin, recordButtonPin);
if (! digitalRead(playButtonPin)) {
delay(10);
while (! digitalRead(playButtonPin));
delay(20);
// OK released!
playServo(servoPin, playButtonPin);
void playServo(uint8_t servoPin, uint8_t buttonPin) {
uint16_t addr = 0;
Serial.println("Playing");
servo1.attach(servo1Pin);
uint8_t x = EEPROM.read(addr);
Serial.print("Read EE: "); Serial.print(x);
if (x == 255) break;
// map to 0-180 degrees
x = map(x, 0, 254, 0, 180);
Serial.print(" -> "); Serial.println(x);
myServo.write(x);
addr++;
servo1.detach();
delay(250);
uint16_t addr = 0;
if (addr != 1024) EEPROM.write(addr, 255);
delay(250);
addr++;
Errors:
You changed the name of the function to recordAllServos. You have to change all the references to that function also.error: 'recordServo' was not declared in this scope
As above. You changed the names of the servo pin definitions. You need to change the references as well.error: 'servoPin' was not declared in this scope
- mlandergan
Ok thank you, I made those corrections and here is my code
But I am still getting these errors:
Teachable_Arm_Mark.cpp: In function 'void loop()':
Teachable_Arm_Mark:10: error: too many arguments to function 'void recordAllServos(uint8_t, uint8_t)'
Teachable_Arm_Mark:49: error: at this point in file
Teachable_Arm_Mark.cpp: In function 'void recordAllServos(uint8_t, uint8_t)':
Teachable_Arm_Mark error: 'readServo' was not declared in this scope
Teachable_Arm_Mark.cpp: In function 'void readAllServo(uint8_t)':
Teachable_Arm_Mark:127: error: 'addr' was not declared in this scope
#include <Servo.h>
#include <EEPROM.h>
uint8_t servo2Pin = 10;
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
Servo servo5;
Servo servo6;
Serial.begin(9600);
delay(10);
delay(20);
// OK released!
recordAllServos(servo1Pin, servo1FeedbackPin, recordButtonPin);
delay(10);
delay(20);
// OK released!
playAllServo(servo1Pin, playButtonPin);
void playAllServo(uint8_t servoPin, uint8_t buttonPin) {
uint16_t addr = 0;
servo1.write(x);
addr++;
servo1.detach();
delay(250);
uint16_t addr = 0;
delay(250);
void readAllServo(uint8_t analogPin)
addr++;
The error message is pretty clear. It looks like you changed the function call signature from:error: too many arguments to function 'void recordAllServos(uint8_t, uint8_t)'
void recordServo(uint8_t servoPin, uint8_t analogPin, uint8_t buttonPin)
to:
Since your new function has only 2 parameters, you can't call it with 3 as before.
- mlandergan
Here is my code as of right now. It is able to load without errors but I am not achieving my goal of having all six servos be recorded/playedback. Any advice?
#include <Servo.h>
#include <EEPROM.h>
uint8_t recordButtonPin = 6;
uint8_t servo1Pin = 8;
uint8_t servo2Pin = 9;
uint8_t servo3Pin = 10;
uint8_t servo4Pin = 11;
uint8_t servo5Pin = 12;
uint8_t servo6Pin = 13;
uint8_t ledPin = 3;
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
Servo servo5;
Servo servo6;
Serial.begin(9600);
delay(10);
delay(20);
// OK released!
delay(10);
delay(20);
// OK released!
playAllServo(servo1Pin, servo2Pin, servo3Pin, servo4Pin, servo5Pin, servo6Pin, playButtonPin);
void playAllServo(uint8_t servo1Pin, uint8_t servo2Pin, uint8_t servo3Pin, uint8_t servo4Pin, uint8_t servo5Pin, uint8_t servo6Pin, uint8_t buttonPin) {
uint16_t addr = 0;
servo2.attach(servo2Pin);
servo3.attach(servo3Pin);
servo4.attach(servo4Pin);
servo5.attach(servo5Pin);
servo5.attach(servo6Pin);
servo1.write(x);
servo2.write(x);
servo3.write(x);
servo4.write(x);
servo5.write(x);
servo6.write(x);
addr++;
servo1.detach();
delay(250);
void recordAllServos(uint8_t servo1Pin, uint8_t servo1FeedbackPin, uint8_t buttonPin) {
uint16_t addr = 0;
readAllServo(servo1FeedbackPin);
readAllServo(servo2FeedbackPin);
readAllServo(servo3FeedbackPin);
readAllServo(servo4FeedbackPin);
readAllServo(servo5FeedbackPin);
readAllServo(servo6FeedbackPin);
delay(250);
uint16_t addr = 0;
addr++;
Your "RecordAllServos" function calls ReadAllServos 6 times in the while loop, but never writes anything to EEPROM.
- mlandergan
I made the correction. The code is able to save the values to the eeprom, but the playing part still doesn't work. Any more advice? Thank you again.
Here is the code:
Here is the code:
//Code Produced
//By Mark Edward Landergan
//Science Fair 2013
//Robotic Arm
#include <Servo.h>
#include <EEPROM.h>
uint8_t ledPin = 3;
int addr1, addr2, addr3, addr4, addr5, addr6 = 0;
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
Servo servo5;
Servo servo6;
Serial.begin(9600);
delay(10);
delay(20);
// OK released!
delay(10);
Serial.print("Play!");
delay(20);
// OK released!
uint8_t x1 = EEPROM.read(addr1);
Serial.print("Read EE Servo 1: "); Serial.print(x1);
if (x1 == 255) break;
x1 = map(x1, 0, 254, 0, 180);
Serial.print(" -> "); Serial.println(x1);
servo1.write(x1);
uint8_t x2 = EEPROM.read(addr2);
Serial.print("Read EE Servo 2: "); Serial.print(x2);
if (x2 == 255) break;
x2 = map(x2, 0, 254, 0, 180);
Serial.print(" -> "); Serial.println(x2);
servo2.write(x2);
uint8_t x3 = EEPROM.read(addr3);
if (x3 == 255) break;
Serial.print("Read EE Servo 3: "); Serial.print(x3);
servo3.write(x3);
uint8_t x4 = EEPROM.read(addr4);
if (x4 == 255) break;
Serial.print("Read EE Servo 4: "); Serial.print(x4);
servo4.write(x4);
uint8_t x5 = EEPROM.read(addr5);
if (x5 == 255) break;
Serial.print("Read EE Servo 5: "); Serial.print(x5);
servo5.write(x5);
uint8_t x6 = EEPROM.read(addr6);
if (x6 == 255) break;
servo6.write(x6);
addr6++;
if (addr6 == 512) break;
servo1.detach();
delay(250);
uint16_t addr = 0;
if (addr1 == 1024) break;
if (addr1 != 1024) EEPROM.write(addr1, 255);
if (addr2 != 1024) EEPROM.write(addr2, 255);
if (addr3 != 1024) EEPROM.write(addr3, 255);
if (addr4 != 1024) EEPROM.write(addr4, 255);
if (addr5 != 1024) EEPROM.write(addr5, 255);
if (addr6 != 1024) EEPROM.write(addr6, 255);
delay(250);
int addr1 = 0;
Serial.print("Read analog pin "); Serial.print(servo1FeedbackPin); Serial.print(": "); Serial.print(a);
EEPROM.write(addr1, a); //save servo 1 values to eeprom
addr1++;
uint16_t b = analogRead(servo2FeedbackPin);
Serial.print("Read analog pin2 "); Serial.print(servo2FeedbackPin); Serial.print(": "); Serial.print(b);
if (b < CALIB_MIN) b = CALIB_MIN;
if (b > CALIB_MAX) b = CALIB_MAX;
b = map(b, CALIB_MIN, CALIB_MAX, 0, 254);
Serial.print(" -> "); Serial.println(b);
EEPROM.write(addr2, b); //save servo 2 values to eeprom
addr2++;
uint16_t c = analogRead(servo3FeedbackPin);
Serial.print("Read analog pin3 "); Serial.print(servo3FeedbackPin); Serial.print(": "); Serial.print(c);
if (c < CALIB_MIN) c = CALIB_MIN;
if (c > CALIB_MAX) c = CALIB_MAX;
c = map(c, CALIB_MIN, CALIB_MAX, 0, 254);
Serial.print(" -> "); Serial.println(c);
EEPROM.write(addr3, c); //save servo3 values to eeprom
addr3++;
uint16_t d = analogRead(servo4FeedbackPin);
Serial.print("Read analog pin4 "); Serial.print(servo4FeedbackPin); Serial.print(": "); Serial.print(d);
if (d < CALIB_MIN) d = CALIB_MIN;
if (d > CALIB_MAX) d = CALIB_MAX;
d = map(d, CALIB_MIN, CALIB_MAX, 0, 254);
Serial.print(" -> "); Serial.println(d);
EEPROM.write(addr4, d); //save servo4 values to eeprom
addr4++;
uint16_t e = analogRead(servo5FeedbackPin);
Serial.print("Read analog pin3 "); Serial.print(servo5FeedbackPin); Serial.print(": "); Serial.print(c);
b = map(c, CALIB_MIN, CALIB_MAX, 0, 254);
EEPROM.write(addr5, c); //save servo 5 values to eeprom
addr3++;
uint16_t f = analogRead(servo6FeedbackPin);
Serial.print("Read analog pin3 "); Serial.print(servo6FeedbackPin); Serial.print(": "); Serial.print(c);
if (f < CALIB_MIN) f = CALIB_MIN;
if (f > CALIB_MAX) f = CALIB_MAX;
EEPROM.write(addr6, f); //save servo 6 values to eeprom
addr6++;
Not sure what you are trying to do here. ReadAllServos reads all 6 servos. Why do you call it 6 times from recordAllServos?
ReadAllServos won't work because all the addresses are pointing to the same place, all the servo data will be overwritten and you will only get one servo's worth of data.
You do not need 6 addresses. There is only 1 bank of EEPROM and you need to write to it sequentially. You only need one address ("addr") just as in the example code and increment it after every write.
Your playAllServo function has the same problem. Use only one addresss ("addr") and increment it after every read.
- mlandergan
ok and also when I am writing each servo their given values from addr, how do I know it is appropriate for each servo.
For example I have this code for void playAllServo
So after this line of code should I repeat this code except do servo2.write and so on?
Serial.print("Read EE Servo 1: "); Serial.print(x);
x = map(x1, 0, 254, 0, 180);
servo1.write(x);
addr+++;
If you always start at zero and read them back in the same order you wrote them, then you will get the right value for each servo.ok and also when I am writing each servo their given values from addr, how do I know it is appropriate for each servo.
Yes.So after this line of code should I repeat this code except do servo2.write and so on?
- mlandergan
Do I need to change the variable x for each servo or can I use the same one?
You can use the same one for all the servos.
- mlandergan
What am I doing wrong?
//Code Produced
//Science Fair 2013
//Robotic Arm
#include <Servo.h>
#include <EEPROM.h>
uint8_t ledPin = 3;
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
Servo servo5;
Servo servo6;
Serial.begin(9600);
delay(10);
delay(20);
// OK released!
delay(10);
delay(20);
// OK released!
void playAllServo(uint8_t servo1Pin, uint8_t buttonPin) {
servo1.write(x);
addr+++;
Serial.print("Read EE Servo 2: "); Serial.print(x);
servo2.write(x);
addr+++;
Serial.print("Read EE Servo 3: "); Serial.print(x);
servo3.write(x);
addr+++;
Serial.print("Read EE Servo 4: "); Serial.print(x);
servo4.write(x);
addr+++;
Serial.print("Read EE Servo 5: "); Serial.print(x);
servo5.write(x);
addr+++;
Serial.print("Read EE Servo 6: "); Serial.print(x);
servo6.write(x);
addr+++;
servo1.detach();
delay(250);
uint16_t addr = 0;
if (addr == 1024) break;
delay(250);
void readAllServo(uint8_t servo1FeedbackPin)
uint16_t a = analogRead(servo1FeedbackPin);s
EEPROM.write(addr, a); //save servo 1 values to eeprom
addr++
