Hello
I'm new in the adafruit world and I'm working with Neopixel Ledstrips for the first time.
I want to connect 4 Neopixel Ledstrips only on one arduino and want to programming every ledstrip independently from each other.
I have already read the description. http://learn.adafruit.com/adafruit-neop ... no-library
but I have still question.
I connect 4 led strips on Aurduino. Every Ledstrip has their own 5Volt power supply.
My question: Can I connect all 4 -(minus)pins of the power supplies with one GND pin on the Arduino?
Or the Arduino has two GND pins? Is it better to use two GND pins, 2 on each GND pin?
Could be there any problem with the current?
Excuse me, but I'm totally new in this Arduino World.
Thank you in advance for your help
How can I connect multiple Neopixel Led Strips on Arduino?
- ozzyjammer
Re: How can I connect multiple Neopixel Led Strips on Arduin
Best to ground each strip back to it's power supply. These grounds will carry the current.My question: Can I connect all 4 -(minus)pins of the power supplies with one GND pin on the Arduino?
Then run a wire from the power supply to the Arduino ground. It is OK to connect multiple grounds to a single ground pin, since these are not carrying significant current. They are just to establish a ground reference for the control signal.
